Old 04-24-2012, 01:06 PM
mack kid mack kid is offline
mack kid is on a distinguished road
Default Flat tire
This is what i have with foam in it.
I heard on forum of filling with silcone but what type and which is the best type.
HELP? i have been looking at differant foams but none i like so far but that would work to i guess? for those who have done it any pics?
Waiting for Parts!
Old 04-24-2012, 01:59 PM
hotwheels000 hotwheels000 is offline
hotwheels000 is on a distinguished road
Default Re: Flat tire
Check out crawler innovations for the new closed cell 2 stage foam he sells. It will support the wieght of the rig yet still allow some confomity to the surface.
Here is a link. I hope it is O/K to link to a vendors site.
http://crawlerinnovations.com/index....mart&Itemid=64
Old 04-24-2012, 02:14 PM
Thanks for the link but he didnt have any 2.2 tire foams but the site gives me an idea maby more like it.
Waiting for Parts!
Old 04-24-2012, 07:27 PM
Double Duece foams are 2.2 foams if that is what you are after. He has them in various hieght and widths.
http://crawlerinnovations.com/index....mart&Itemid=65
Old 04-25-2012, 01:49 PM
Thanks sent e mail out to crawler inovations see what happens also looking at silicone fills
Waiting for Parts!
Old 04-24-2012, 02:15 PM
ihbuilder's Avatar
well if your using the stock foam with any kind of weight , I'm not supprised I thought of using rtv silicon in my mack I just didn.t get to it yet . check alumilite for casting silicon . I'll get you a link if you need .
Old 04-24-2012, 06:10 PM
doodlebug's Avatar
Thank's Steve! http://www.alumilite.com/
Cheer's, Neil.
Old 04-25-2012, 03:40 PM
doodlebug's Avatar
I read somewhere, that pool noodles could be used for tire liner's, are they stiff enough for you? http://www.google.com/products/catal...=0CKABEPMCMAA#
Cheer's, Neil.
Old 04-26-2012, 04:00 AM
Thanks Doodlebug try them today let you know how it works.
Waiting for Parts!
Old 04-26-2012, 01:58 PM
Well tryed pool noodles and some other foam and did not work was a little better but not worth the pics i guess its silcone or change tires.
Waiting for Parts!
Old 04-26-2012, 08:01 PM
doodlebug's Avatar
Darn! I'm wondering if the sidewall was filled up half way to start with? if that would be soft enough, or fill it the rest of the way if it's too soft? More brain cramp's!
Cheer's, Neil.
Old 04-27-2012, 07:18 AM
i made the foam bigger then original inserts thinking it would not work and pop tire off beed but tire stayed on but still too much sag back to drawing board
Waiting for Parts!
Old 04-27-2012, 07:37 AM
dabears's Avatar
dabears dabears is offline
Dumb idea maybe but what about great stuff sprayfoam?? It would be permanent buy might hold up? Maybe spray into a sandwich bag inside tire trim then take outof bag when it's fully dry? It's pretty tough stuff. And a can is pretty cheap. Just a thought, Havnt tried it myself yet....
Old 04-27-2012, 10:43 AM
I used camper tape on my Euclid front rims and it worked well. The tires hold up the truck and a 6lbs lead acid battery. I put plastic rap on the rim and rapped the camper tape around until it was the right size and then slid it off and crammed it into the tire. The tricky part is getting the tire streched over the tape but once it's in there you slip the rim back in and you're good to go! There is probably better ways but this was cheap, almost instant and seems to work.
Reg
Old 04-27-2012, 01:14 PM
Oooooooo i like both those could even make mold for great stuf? RCP57 camper tape is good but what is camper tape
Waiting for Parts!
Old 04-27-2012, 01:45 PM
It's just weather striping on steriods. It comes in various widths and thicknesses. People use it between truck bed rails and canopies ect. It has adheasive on one side. You can find it at an automotive or a hardware store.
Reg
Old 04-27-2012, 02:02 PM
gotcha give it a try Thanks Don
Waiting for Parts!
Old 04-27-2012, 01:25 PM
dabears's Avatar
Yea you prob could make a mold for the great stuff.. And it's pretty durable. Let me know if it does work
Old 04-27-2012, 03:19 PM
Air rifle BB's packed tight into the tire, a bit of tire buldge still appears when you're loaded heavy.. the added weight helps for bobtailing too and locks the tire to the rim.
