Has anybody run across blueprints or plans for these trucks? I've searched high and low and keep coming up empty handed. All I seem to find is pics and brochures. I'm desperate to find some info with dimensions on it so I can get to building my truck. I've collected all kinds of parts and their just sitting in a pile staring at me driving me nuts....... Ive even been searching eBay for a Nikko 1/10 r/c but that's a needle in a haystack, they seem to be very hard to come by hese days seeing as I've been searching for about a year now....
Any help would be appreciated so that I can get going. I'd even take some measurements of a r/c if you have one. --Dan
Dan , here's some base dimensions , it gets you a general over all to scale a good side pic . http://www.carsdirect.com/2007/inter...al/cxt/specs#b
That will def help me get started on it, I appreciate the link
--Dan
Careful - tamiya chassis are not scale width for length or height - best to double check your figured dims to your base chassis
I'm doing full custom on it, w FGD Rails and I'll mill my own supports if I need to. I'm using rc4wd D40 axles and 2.2 mil spec rims and tires. The only reason I need the dimensions is the front cab is very similar to the cxt but the rest is completly different. It's a military truck just to give you an idea. I origionally was doing an MRAP but was beaten to the punch so I switched up trucks and now am pulling teeth trying to find the specs on it.
--Dan
Hmmm the MXT buy any chance
I had thought about the mxt but wasn't sure I'd like it enough so I went bigger with another axle.
![]() --Dan
