Old 08-05-2012, 06:53 PM
dmess62's Avatar
dmess62 dmess62 is offline
dmess62 is on a distinguished road
Default help needed
I've got a motor issue. When pulling my trailer with my King Hauler(55t motor and 9 tooth pinion) when it gets into a little strain going up slight incline the motor starts cutting out. This is in 1st gear. Any suggestions as to the problem. I never noticed it with no trailer
Thanks for looking. All comments, suggestions, and constructive criticism are appreciated.
Dave
Old 08-05-2012, 08:07 PM
dabears's Avatar
dabears dabears is offline
Default Re: help needed
Mine kinda does the same thing,I just give it more throttle. I have the same set up 55 turn and a 9 tooth gear. With 50#of load I really have to throttle up on an incline. (my daughter sits on the trailer)
Old 08-05-2012, 08:24 PM
rc_farmer's Avatar
Master Builder
Are U guys running any other GRU, if not or even if so, try chaning that 9t out to a 6t, U will a lot better pulling power in fisrt gear.
Giving up is not an option!!!
Rob
Old 08-05-2012, 10:10 PM
dmess62's Avatar
no gru. i put in the 9 tooth because I hadn't had time to order a 6 tooth
Dave
Old 08-05-2012, 10:08 PM
dmess62's Avatar
that is with the throttle all the way up also. Its like the motor is turnining off and on. do you have any pic of how u spaced the motor with the 9 tooth. i didnt pu any thing in mine
Dave
Old 08-05-2012, 08:43 PM
dabears's Avatar
how much more mods are needed for a 6tooth? the 9 tooth needed a spacer between the motor and trans, but i may need to re adjust mine as i get a geary noise in first gear.. idk
