Old 09-25-2012, 02:22 AM
motocrawler motocrawler is offline
motocrawler is on a distinguished road
Default Bruder Liebherr 574 Conversion
Hi guys!
Just wanted to introduce myself, and say I have been lurking around this site for the last month and have been soaking up all the amazing information. I thought I would post up my Bruder Loader conversion.
So the parts required for this conversion are:
Tamiya Semi axles
Tamiya CR-01 transmission
1x Hitec Hi - torque mg servos
Set of Tamiya Hummer rims
Set of axial 1.9" tires
3x Linear servos or Linear actuators (I am using Ferigelli Linear servos for this build)
A bucket load of Tamiya Hi-lift hardware
Step 1: Dismantling
Old 09-25-2012, 02:31 AM
Default Re: Bruder Liebherr 574 Conversion
Step 2: Figure out how to connect the linear actuators to make the boom and bucket work properly. I started by cutting and drilling a hole at the bottom of the boom chassis.
The cut was required to gain the proper clearance and the hole was drilled to push a brass rod through to connect one end of the actuators
From there I drilled a hole through the booms to connect the other end of the actuators
The bucket ram was easy to install, I just drilled a hole through the existing mounts
Old 09-25-2012, 02:45 AM
The next step in the process was figuring out how to make the articulated portion of the loader work. As easy as the photos make it seem I actually spent a lot of time trying to figure out what would give me full travel and yet be out of the way and not require to much hacking of the body/chassis.
Now came the tricky part, how to get power to the wheels. I am using Tamiya semi axles as they are a exact match width wise as the original axles. This was a serious multi step process with a lot of swearing and head scratching.
Step 1: Mask and cut clearances for axle, the point of no return!
Before
After
Step 2: Make brackets to hold the axles to the chassis
Step 3: Lock the diffs-a nifty little trick-insert a 4th bevel gear and viola she is locked
Step 4: Paint axles and brackets and assemble
Step 5: Mount axle to chassis
Old 09-25-2012, 02:53 AM
Once I got the rear axle in I worked on the motor and transmission. I made these aluminum motor mounts
With motor mounted
From there I moved to the front axle, I had to make alot of cuts to get it to fit but she did!
Made some mounts for the axle and installed them
From there I made a custom drive shaft and connected it to the axles
From there I put it all back together sans cab
Old 09-25-2012, 02:57 AM
Here is a quick video of the test run...still need to get use to the controls and get a smoother speed controller...but she is powerful.
http://www.youtube.com/watch?feature...&v=famTtbUEBJ4
Old 09-25-2012, 04:14 AM
Very nice done, looks very powerful and good traction! Maybe need for alu or steel arms and linkage? Looks a little wobbly! Well done!
Old 09-25-2012, 09:31 AM
Here are some final finished shots of the loader.
I will try to get some video of it in the next few days. I actually built a 1/16th scale short course track in my back yard with this, the excavator and dozer.
Old 09-25-2012, 08:15 PM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Very nice loader conversion ,looks like it works great ,look forward to some more vids
Old 09-25-2012, 09:24 AM
Madda Madda is offline
Oh, one of the best bruder conversions I've seen. You did very great job on hiding the servos making everything look scale!
Now take off all orange stickers, make better wheel hubs and finish the cabin and we have a very cool model!
Keep it up!
Old 09-25-2012, 08:43 PM
dabears's Avatar
dabears dabears is offline
Looks really good!! Looks like it works well. I love the conversions people do. One of these days ill start mine.
Old 10-01-2012, 12:23 AM
rc_farmer's Avatar
Master Builder
Very nice conversion. I like the clean look.
Giving up is not an option!!!
Rob
Old 11-02-2012, 11:42 AM
Ths Ths is offline
Ths is on a distinguished road
Very nice. Do you have the specifications of the linear servoes you used?
Old 11-03-2012, 02:29 PM
caterpillar caterpillar is offline
caterpillar is on a distinguished road
great conversion! dying to see more pics and video's of it. I have one of these at home too, maybe I should also convert it.
Old 11-03-2012, 06:01 PM
rcman rcman is offline
rcman is on a distinguished road
very sweet! you did a great job! i like the linear servos looks like they were made for it!
Old 11-03-2012, 06:13 PM
I see that in one pic you have a single 645 servo and in another you have two servos. What servos did you end up using for the steering?
Reg
Old 11-04-2012, 10:07 AM
mog mog is offline
looking good you got it done up nice all i ever did was get my 574 taken apart lol.
Old 03-06-2013, 07:47 AM
kcusumano kcusumano is offline
kcusumano is on a distinguished road
lookin great but I would have converted a ertl case 1/16 scale pay loader model looks so much more american and scale
Old 04-23-2013, 12:20 PM
farmhauler farmhauler is offline
farmhauler is on a distinguished road
awesome! i have one coming in the mail and this thread is gonna help me out alot!
Old 04-26-2013, 04:58 PM
pumptech's Avatar
How are the Linear actuators working out for you on the loader ..
Old 05-27-2016, 05:08 AM
rc_nut rc_nut is offline
rc_nut is on a distinguished road
Smile Re: Bruder Liebherr 574 Conversion
Hi there,
Iam going to do the same.
Can you please, please tell me what Linear actuators you used?? Thanks
Brian
Tags
bruder, conversion, dirt, liebherr, loader
