Construction Equipment Tech Hydraulics, Electronics, General Engineering, ect in constr equip |
Hi,
Does anyone know where I can buy gears like these online? ![]() ![]() ![]()
HI YOU COULD TRY MUFFIT GEARS AT www.muffitt.co.uk they do a fantastic range of gears at sensible prices and I think there minimum order is about 10 GBP hope this is of some help cheers John
when you find out let me know . I emailed the place Ari gave me but have not heard back from them yet . http://www.hpcgears.com
JB , that link is no good
http://www.sdp-si.com/eStore/CoverPg/Gears.htm
This is where I order all my gears from. Large selection of miter gears or what ever you want. Not everything is in stock all the time and the prices are decent but very easy website to use and order from. Just make a shopping cart and order. No minimum of an order as long as you pay by credit card. Every other good gear supplier I have found is a quote/contact to order. That's just too time consuming to me. There is also http://www.mcmaster.com/#standard-gears/=jhalkw but this is a limited selection. I've bought miter gears pretty cheap once before from ebay. Hard to find what you want though. -Jeff Last edited by Jw.; 09-27-2012 at 08:26 PM. |
Kerst |
I'll have a look: http://www.muffettgears.co.uk/
McMaster does have some gears like these, as already mentioned. I bought a set myself, but they get pricey, if you need a lot of them. McMaster has both nylon and metal gears, of various strengths. The stronger they are the more they cost. The other thing is most are either held with set screws or keyways and set screws. I don't know that I would trust a set screw, but maybe if the gear was pinned to the shaft instead, it would hold without slipping. Or at least you would need a flat on a shaft for the set screw to bite into. Some guys are able to score gears like these out of cheap hand grinders too. Sometimes it pays to look around.
Nathan |
