Old 10-05-2012, 03:34 PM
kamyoncu's Avatar
kamyoncu kamyoncu is offline
kamyoncu is on a distinguished road
Default 1:14 Liebherr LR 634 Carson - Leimbach
Hello to all my friends
Here is my new 1:14 Liebherr LR 634 Carson tracked loader. I will use Leimbach hydolic system on it. As electronics, I bought servonaut BMA and M220. I am looking for a original sound system for my tracked loader not like servonaut SMT.
Opening boxes
According to manuel the first issue is side trunks of track, however it is unpainted. Firstly I thought join parts unpainted than I change my mind. Now I paint spoon and side trunks. I used RAL 7016 for downside parts and I will use RAL 1007 leibherr yellow upside parts. I want to construct a original standart painted car.
CAT: 963 B Scaleart // 345D LME Wedico // CS 563 E Handmade
Mercedes Benz: SK 3544 AK 8x8 Premacon // NG 2636 AK 6x6 Wedico Handmade
MAN TGS 26.500 6X6 Wedico - Premacon
MACK Granite 8x6
Old 10-05-2012, 03:40 PM
kamyoncu's Avatar
Default Re: 1:14 Liebherr LR 634 Carson - Leimbach
RAL 7016 provided perfect color in perfect condition, but 1007 could not provide as the same performance; therefore, I will buy auto paint instead of spray.
I used metal tooth instead of standart plastic ones.
Than I jointed motor and its connection parts.
MACK Granite 8x6
Old 10-05-2012, 03:41 PM
kamyoncu's Avatar
Here is joining of tracks.
I painted downside the orginal liebherr gray.
Montage of gearbox and motors
And spoon was painted same color with the downside.
MACK Granite 8x6
Old 10-05-2012, 03:47 PM
kamyoncu's Avatar
I joined and sticked upside parts.
I started paint the parts to original Liebherr yellow.
MACK Granite 8x6
Old 10-05-2012, 03:50 PM
kamyoncu's Avatar
After paint dried, I add my stickers instead of Carson. The reason that is stickers very weak and they can easily spoiled. After aplication of stickers, I spreyed polisher on al cab, so it saves both paint and stickers. Note: Bostancı insaat means BOSTANCI CONSTRUCTION COMPANY
I added tracks.
MACK Granite 8x6
Old 10-05-2012, 03:51 PM
kamyoncu's Avatar
Now I added hydraulics. I wonder why fittings are smaller than nipples ? It is impossible to fit them on the input and outputs of valf. If you guys have any idea please let me know.
MACK Granite 8x6
Old 10-05-2012, 04:14 PM
I was going to ask what the distance between the tilt & loader arm holes were on the bucket, but you have it all assembled already!
I wonder if it'd be possible to get the bucket seperately?
Old 10-05-2012, 06:24 PM
kamyoncu's Avatar
@ Lil Giants, forgive me I could not understand the points. Could you show them on a picture ?
I did not assembled, I just put all them all together, I know you are a professional, If you have any idea for improvement I open to all.
MACK Granite 8x6
Old 10-05-2012, 06:37 PM
pumptech's Avatar
pumptech pumptech is offline
Nice build ,congrats on your new trackloader,About how long did it take you to put it all together?
Old 10-05-2012, 07:05 PM
kamyoncu's Avatar
because of painting It took 10 days. I finished my wedico cat 345d lme in 3 days It does not take so much time if there is not massive painting issues.
MACK Granite 8x6
Old 10-05-2012, 08:31 PM
Claus's Avatar
Claus Claus is offline
Awesome build! Looks challenging.
Old 10-05-2012, 10:54 PM
I might like to purchase this bucket from the Carson loader, if it is sold seperately, for a different loader model that I have. The distance between upper & lower pin holes of my current bucket is 35mm, which greatly impairs the curl radius at a low level. I'm currently using a bucket from the Bruder track loader and that particular distance is about 30mm & the bucket dumps sharply at a much lower height.
Old 10-06-2012, 02:49 PM
kamyoncu's Avatar
You are lucky because lenght is very nearly 35 mm. I am not sure does they sell bucket separetely. However, I believe that it will be fit for you tracked loader.
MACK Granite 8x6
Old 10-06-2012, 05:33 PM
sandfarmer's Avatar
sandfarmer sandfarmer is offline
sandfarmer is on a distinguished road
Nice loader, good job!
Old 10-08-2012, 12:31 PM
MoRockN's Avatar
MoRockN MoRockN is offline
MoRockN is on a distinguished road
Nice looking model. Mine just shipped a few days ago. Thanks for sharing.
If you got it, a Trucker brought it....
Old 10-09-2012, 04:21 PM
kamyoncu's Avatar
Although cap was white, I used spray polisher to get realistic view.
I added oil depot detail. I painted metallic head of it.
I made little shorter hydraulic hoses than leimbach offered. So my system works more efficient.
After hydraulic done, I mounted servonaut m220.
I directly mounted leimbach hydraulic esc to m220. I can directly control hydraulic motor speed and on-off properties from radio.
MACK Granite 8x6
Old 10-09-2012, 04:27 PM
kamyoncu's Avatar
I have a question to users of raupen and dozer
Did you guys recommend to add more weight on the loader and how many kilo does it takes Scaleart CAT ?
used 12 volt battery on the videos. I wait my 4s lifepo battery it will be 13.2 volt so, my raupe will be more strong.
Here is the videos of hydrolic test and driving test
http://www.youtube.com/watch?v=6F1tr...&feature=g-upl
http://www.youtube.com/watch?v=1-yP3...&feature=g-upl
MACK Granite 8x6
Old 10-10-2012, 09:53 AM
Alokocat Alokocat is offline
Alokocat is on a distinguished road
Hi Kamyoncu,
Very nice model, the one I dream of héhé
The scaleart 963B is at around 10kg. You should try to add some more weight to yours, I've read somewhere that with the Carson at 9kg, it runs great and has better traction.
In your first videos we can clearly see some foam in the hydraulic oil tank, you should add more oil, until around 3/4 of the full tank, it is very important.
Please add more videos as you run this beauty in some dirt
Old 10-10-2012, 02:00 AM
This looks like such a cool model! I want one very badly! Where did you purchase the hydraulic kit for the model? Do you think you will have enough room in the chassis for all the electronics, especially with the addition of the hydraulic system?
Nice videos. Seems to have excellent performance! The hydraulics are very responsive. Good to see the bucket has an improved tipping geometery. Perhaps that bucket cylinder has just a tad to much stroke, as it begins to curl the bucket back in, once the linkage passes the maximum extended limit? A very minor problem, if at all.
Old 10-10-2012, 06:46 AM
ptebbe ptebbe is offline
ptebbe is on a distinguished road
Looks Great!
What are the tracks made of....plastic, aluminum?
Did you have to paint all the track pieces individually?
