Old 11-18-2012, 03:55 PM
rcguyfarms rcguyfarms is offline
Location: Up a hill above the dirty Ohio river on the Indiana side.
rcguyfarms is on a distinguished road
Default garden tractor with loader
I have stepped up to a real type of loader for less or same cost of my rc equipment. I have been searching for 2 years to find a good deal on an older john deere large size garden tractor. I was going to scratch build a loader for it. Well last tuesday my long search was over I found a john deere 400 garden tractor with a loader on it for $3500. The tractors that size go between 2500 to 3000 with just a mower deck around where I live. Even better part was the tractor had a brand new kolher 20 hp motor already in it. Tractor ran fine and u could only run the loader at idle when I got it. The issue was how the pump was mounted and the major oil leak out one of the tilt cylinders. I was able to find a new seal kit and fix the hydro oil leak. I finally got the pump lined up and now it runs at full rpm or I usally run at 2/3 full rpm to save on fuel. I plan to add a 3-point hitch and a couple of implements to aide in dirt and snow work. I have switched to filled bar type tires in the rear and will put on new front tires also.
Old 11-18-2012, 05:20 PM
Claus's Avatar
Claus Claus is offline
Default Re: garden tractor with loader
There is nothing more handy than a loader tractor. You will wish you had 4WD though, love my compact tractor as much as my utility tractor.
Old 11-28-2012, 07:55 AM
Stepside's Avatar
Stepside Stepside is offline
Super Moderator
Stepside will become famous soon enough
I don't know how "compact" your "Compact Tractor" is, Claus!!!
nice score Scott!
"If you build it, they will come"
East Coast Mini Truckers
Old 11-18-2012, 07:54 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Fantastic find Scott. I'm so jealous. Take care of it!
Old 11-18-2012, 09:29 PM
Nice find, Scott. You going to RC it? Gives you the best of two worlds!
Old 11-19-2012, 06:35 AM
I am not going to rc way to much fun just operating it. I have thought of the idea to maybe build a 1/10 scale one to go with my rc version of my real truck.
Old 11-19-2012, 11:45 AM
Acadieman Acadieman is offline
Acadieman is on a distinguished road
Nice garden tractor.
And you have the ZTR for mowing duties, good combo.
Old 11-20-2012, 10:09 AM
Thumbs up Re: garden tractor with loader
NICE I've operated enough loaders in my day to agree with Craig (Claus)
I also like larger equipment personally, but I'm a big guy
- RCT
WCMT Director -
Old 11-20-2012, 11:29 AM
It all depends on the size of the yard.
I was never a big fan of garden tractors, until I realized what they could do.
My father has a 60hp Kubota to maintain 3 driveways (all over 300ft) and 180acres of land, but that would be a overkill for most households. If the property is mostly lawn, a big machine is not needed.
I drove 4wd tractors, although nice they come with a price tag, and again it all depends on the use of the machine. There are still lots of 2wd tractors and industrial machines used on a daily basis, and I'm sure there's a reason for that.
I would like to build a mini loader for the JD 180 lawn tractor we have. That's one tough little tractor, and its currently only used to pull the trailer and sprayer.
Old 11-23-2012, 03:42 PM
I fabricated my own weight bracket. Also I got in some 3PT drawbars and a 3PT hitch for the tractor. I took one drawbar and welded up my old aerator to it so I can use it on the 3PT hitch.
Old 11-23-2012, 03:44 PM
Finster's Avatar
Finster Finster is offline
Finster is on a distinguished road
Very Nice! Wish I had one, sure beats shoveling!
Brian
Finster shavin' and smokin' a cigar?!?!
Old 11-30-2012, 04:17 PM
The lights that are stock on the tractor just don't cut it for night time work. I found some 9 led 27w 4.5 lights on ebay for great price. I mounted a pair the leds to the loader arms and one on the back. I pigged tailed the positive side off the light switch and negative ground. Also added a 2 position headlight switch to turn off when not needed or run the fronts only or run all the led work lights.
Stock lights
leds turned on
Old 11-30-2012, 04:35 PM
doodlebug's Avatar
You'll be very happy with those led light's.
Used mine all winter on night shift, I-15 CORE job, best backup light's around!
Cheer's, Neil.
Old 04-13-2013, 08:51 PM
Petedrivinman Petedrivinman is offline
Petedrivinman is on a distinguished road
Nice garden tractor and loader,bet thats fun playin around with
