Old 12-30-2012, 03:28 PM
dmess62's Avatar
dmess62 dmess62 is offline
dmess62 is on a distinguished road
Default possible reflectors or lenses
Been thinking about this for a little bit, figured I'd go ahead and try it to see how it looked. These are some of the little lenses that I "borrowed" from my kids lego stuff. drilled a hole in some styrene and mounted the lego lenses. I was thinking that they would make cool reflectors or possible light lenses.
What do you guys think.
The back side
Thanks for looking. All comments, suggestions, and constructive criticism are appreciated.
Dave
Old 12-30-2012, 06:21 PM
Default Re: possible reflectors or lenses
That's a cool idea, and i've thought about this myself. But my concern is the word "lego" showing. How did you remove the raised part?
Old 12-30-2012, 06:35 PM
dmess62's Avatar
I didn't remove anything from these. the one pic shows the letters but i don't think they are raised, i'll have to double check. If it is you coulcld probably use fine grit sandpaper to remove
Dave
Old 12-31-2012, 12:48 AM
Mama Sue's Avatar
Mama Sue Mama Sue is offline
Mama Sue is on a distinguished road
Good Idea...I can just hear it now....."Mom, he's using my legos"
Old 12-31-2012, 12:03 PM
dabears's Avatar
dabears dabears is offline
Yep mine will be yelling that one later when i test this theory out.....
Old 12-31-2012, 02:37 AM
Thumbs up Re: possible reflectors or lenses
I use parts anywhere I can find them. Insulin bottles, empty medicine containers, left over wood from projects around the house... anything that I can find useful. It just takes a little imagination.
I like the looks of the Lego "reflector/lights". It's a good idea and is possibly cost effective. I purchased similar lights that were operational from Radio Shack for just a couple of dollars for my Knight Hauler.
- RCT
WCMT Director -
Old 12-31-2012, 09:43 AM
Lego light lenses can be flipped either way. If you use the lenses one way, the Lego logo shows, and is raised up slighty, but if you flip the lenses the other way, the Lego logo is mostly hidden, and the lenses are sunken in. Of course you'll still see the Lego logo, if you look hard enough, but it will be backwards, when viewed from behind. I think that's why you can't see the raised bump, which would attach to a Lego brick. He's got them inserted into the styrene backwards, techincally, or else he has them inserted the right way, but he only drilled the hole large enough to accept the little bump, and the rest of the lense is hidden behind the styrene.
Old 12-31-2012, 12:25 PM
dmess62's Avatar
I drilled the hole for the smaller bump thinking it would look flush to the outside. I think it's a 3/16 hole and its a tight fit, no glue needed. I also held up a 5mm led to the backside and it would sit in the hollow part just need a way to hold led in place
Dave
Old 01-04-2013, 03:08 PM
Supermario's Avatar
Great idea! The one pic showing the back side of the lens has a nice rim. Could you cut a slot , slide a 5mm bulb wire into it and make a plug for the end to secure maybe?
Or good old silicone?
Mario
Old 01-04-2013, 01:43 PM
Goose19's Avatar
Goose19 Goose19 is offline
cool idea. I'm going to buy some lego for my kids! *wink*
