Old 10-26-2010, 09:07 AM
johnboyee johnboyee is offline
johnboyee is on a distinguished road
Default Hydraulic pump pics?
Does anybody have pics of any of these miniature pumps taken apart, or exploded view, I know what a gear pump looks like, I'm just lookin for some pics of these, thanks
Old 10-28-2010, 08:27 AM
Default Re: Hydraulic pump pics?
Ok, no pics, the main question is the gears, what size, where might u get them?
Old 10-28-2010, 11:47 AM
Vanisle Vanisle is offline
I don't have any photos other than the diagram in my other post that I will work from to try and make one ... one day. As for gears, you can make them yourself (with a lathe, milling machine and gear cutter) or buy them from various sources. A couple of common sources of gears are McMaster-Carr and SDP-Si.com (Stock Drive Products). At this stage I have no idea about gear sizes, DP and mesh.
Old 10-28-2010, 01:03 PM
pugs pugs is offline
The gears would be a pair of the same size, and should be special pump gears not ordinary power trans gears. The pump gears are shaped differently to make the gear pair seal up to each other better. They also need to be ground for thickness to be 0.0004" thinner than the housing depth so as not to allow oil seepage around the sides.
If I could find a source for good pump gears, I'm sure I could build one (or multiple) just haven't been able to find a good source of small ones yet.
Jeff
Old 10-28-2010, 01:54 PM
dirtpusher9's Avatar
Moderator
Here's a pic of the inside of the pump.
The gears measure 6.90mm OD.
Old 10-28-2010, 03:59 PM
wow , I guess I'll have plenty of volume with mine just hope I get the pressure
Old 10-28-2010, 04:13 PM
tracksntreadslou's Avatar
Here are a few pics of the inside of a jung pump..same one as whats running in Eds (jammers) excavator..These will pump up to 120 bar 1680 psi
Old 10-28-2010, 05:36 PM
Nice pics guys, thanks, joe,I assume there is a another cover over those gears and all that is inside the tank! How thick are those gears roughly?
That Jung pump looks like an efficient, little more to difficult for me to make! But at 160 bar, that's nice!
Old 10-28-2010, 08:09 PM
Moderator
[QUOTE=johnboyee;9705]Nice pics guys, thanks, joe,I assume there is a another cover over those gears and all that is inside the tank! How thick are those gears roughly?
You are correct. Their about 4 mm.
Old 10-30-2010, 08:08 PM
mog mog is offline
thanks for the info joe now i know i was going down the right path with the pump that i am plaing with as well.
