Old 11-11-2013, 11:13 AM
rsd53 rsd53 is offline
rsd53 is on a distinguished road
Default Transmission options
I'm trying to get an idea of what you guys would recommend for a transmission for my Tonka conversion. I have a stock Tamiya motor and 3-speed transmission, but I won't have enough room inside the cab to use them.
I'm looking for something I can use a 540 motor with, that is shorter in length, height, and isn't too expensive.I haven't had much luck with the vendors sites, when it comes to price.
Thanks, Rob
Old 11-11-2013, 01:06 PM
JAMMER JAMMER is offline
Default Re: Transmission options
Rob check out RC4WD for a transmission they have a 2 speed that is fairly compact. Ed
Old 11-11-2013, 08:24 PM
Ed, that one is on my list, but a little more than I want to spend. I do think it would be a great fit though.
Old 11-11-2013, 05:20 PM
Stuff's Avatar
Stuff Stuff is offline
HD semi version (new) http://www.wtbcar.com/shopping/index...product_id=203
what I have in mine - http://www.wtbcar.com/shopping/index...product_id=154
or try a rc4wd dig tranny?
my YouTube is -
Subscribe!!
My Facebook -
Old 11-11-2013, 08:29 PM
Thanks for the links. I really like the looks of these, and the low profile they provide. however both are on the upper limit of my budget. I had never been on that site before, but I do plan on checking them out more thoroughly.
Old 06-06-2015, 10:55 AM
wtbcar wtbcar is offline
wtbcar is on a distinguished road
Thumbs up Re: Transmission options
thanks for using WTBcar items !
Old 11-11-2013, 09:26 PM
I've also been looking at the RC4WD planetary transmissions. If I coupled a 16:1 with a 65t motor, I would probably have all the speed I needed.
Is anyone using one of these?
Old 11-12-2013, 08:23 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
A bit different approach here - but take a look at some of the robot shops - they carry electric motors with gear reduction units already attached. sometimes they are more affordable. but they are generally more compact.
Old 11-13-2013, 06:24 AM
Izzy, that's a great idea, and I will start looking into that option right away.
Old 11-23-2013, 02:28 PM
I too would suggest looking at the planetary style gearmotors. You might even consider robbing such a set-up from a cheap power screwdriver, or an old cordless drill. You could run a rear axle, using a driveshaft with that set-up, or you could also drive the wheels directly off the output shaft of the gearmotor, although then you will one motor for each wheel you wish to power.
Old 12-16-2013, 03:44 PM
Rimrock Rimrock is offline
Servonaut planetary gearmotors are strong, quiet and compact. Over here in the old world a lot of folks that are into RC trucks, quickly throw out the noisy, backlashing Tamiya 3 speed, and it's motor which is more suitable for Formula 1...Most popular is the GM32U370, 7.2 V and output speed of about 370-400 rpm. (The speed with a standard 1:2.666 differential with equal 2'nd gear on a standard Tamiya 3 with a motor turning 6-7000 rpm, as of e.g an LRP Truckpuller) Will give a speed of 1.5 mph, which many find very suitable, and have no trouble dealing with total weights of 50-60 lbs. there is also the GM32U450, 12 V, which got double power. Costs about 100 USD. I don't know if there are any dealers over there, or what shipping cost from Germany. Will be cheaper disassemble a battery screwdriver, if one comes over one with a suitable rpm. About 150 rpm on the wheels of Tamiya 1:14 size tires gives the 1.5 mhp speed..
Old 01-22-2014, 12:49 AM
ricm ricm is offline
My vote would be a pre-assembled gearmotor as suggested by Izzy - absolutely right to look at the robot parts suppliers....
try http://www.technobotsonline.com/
these guys have a HUGE range to suit pretty much anything. And pricing is pretty good
Old 02-10-2014, 05:52 PM
RodneyO's Avatar
RodneyO RodneyO is offline
RodneyO is on a distinguished road
has anyone used this transmission in any of there builds?If so what is your opinion on it?Thanks
Old 01-26-2015, 12:11 AM
RoadFlyer's Avatar
RoadFlyer RoadFlyer is offline
RoadFlyer is on a distinguished road
I just put one of these into my Knight Hauler. Tried it first with a RC4WD 80 turn modified Crawler motor...a little too slow. Next put the original 540 Tamiya motor that came with K.H...runs great. I've got 2 speeds instead of the stock 3 speeds. These planetary gears are much quieter than the stock 3 speed Tamiya transmission and a lot smother. I would recommend this as a must do for all the Tamiya truck line.
Old 01-27-2015, 12:44 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
RSD,
How you coming on the tonka drivetrain project? I have two dump trucks and the truck chassis under my dragline that I want to convert. I have bought a few differential sets from odd assorted RC cars but have not landed on an ideal solution yet.
Jim
Old 07-23-2017, 02:02 AM
Your recommendation is enough for me. I just ordered a 1:14 version to put in the KH I have.
Old 06-10-2015, 11:40 PM
Dreamweaver's Avatar
Weaver Of Dreams
I have it in my truck. I believe I'm using a 55t. It' not fast.
http://vid587.photobucket.com/albums...6061902050.mp4
Mike "DREAMWEAVER" Johnson
Old 02-10-2014, 06:52 PM
Stuff's Avatar
I have a 14:1 on the way from korea. I'll see what it's like when it gets here. might be too slow at 14:1 for drive motor but it is intended for my lift. there is a lower reduction to which might be what the RC4WD ones are.
my YouTube is -
Subscribe!!
My Facebook -
Old 02-10-2014, 08:02 PM
RodneyO's Avatar
Thanks.I've seen a 1:5 ratio one also on eBay.I'm running a 45t motor from rc4wd.Appreciate you giving me your input.
Old 02-11-2014, 07:41 PM
A 4:1 or a 5:1 is a good auxiliary reduction box to add to another main transmission, but you'll want a lot more reduction than that, if you are thinking of replacing a Tamiya 3 speed with a more compact planetary or spur gear transmission.
