Old 08-02-2014, 04:22 PM
modelman modelman is offline
Default Milling a 4-jaw chuck??
Okay machinist, I need some help. I bought a 4-jaw chuck for my lathe since I need to turn round ends on some .125" square shaft. The chuck will only close to .250". Could the angled sides of the jaws be milled down to make the jaws move further in or are they hardened? I ran a file across the edge and it cut but I'm not sure if they are hardened.
Old 08-02-2014, 06:11 PM
mtloperator mtloperator is offline
mtloperator is on a distinguished road
Default Re: Milling a 4-jaw chuck??
If you cut them with a file you can mill them with a cold carbide cutter . If 2 piece you'll need to do both . The best solution would be a square collet if you have a collet chuck or nose .
Old 08-02-2014, 06:41 PM
doodlebug's Avatar
Make some shims for the stock and fill in the gap with them!
Don't mess the jaws up!
Cheers, Neil.
Old 08-03-2014, 12:00 AM
Ken Orme Ken Orme is offline
Ken Orme is on a distinguished road
I agree with Doodlebug.
Chucks are expenive. Use shims.
Old 08-03-2014, 05:22 PM
Cheers, Neil.
I agree-chucks are expensive!!! That's why I think using shims is a terrible idea. I have 12 ends to round and that would require a lot of set-up time. For what I paid for this I want to use it as it was intended. It is a 6" dia chuck and I actually need a 5' dia. so I think I will send it back and buy a 5" that will close to .125" if I can find it and so far I have not.
Old 08-03-2014, 12:12 AM
Finster's Avatar
Finster Finster is offline
Finster is on a distinguished road
Perhaps you can machine a set of replacement soft jaws yourself?
Brian
Finster shavin' and smokin' a cigar?!?!
Old 08-03-2014, 09:44 AM
How big is the chuck.
I have used penies for shims.
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
