Old 05-02-2014, 01:47 PM
Seilbagger's Avatar
Seilbagger Seilbagger is offline
Seilbagger is on a distinguished road
Default simple device to build cheap and exactly leave springs
Hello all,
i've made this a few weeks ago
Part 1:
Material is bronze, the eyes are soldered in a Shell of brass
Best Regards
Wolfgang
Old 05-02-2014, 01:51 PM
Seilbagger's Avatar
Default Re: simple device to build cheap and exactly leave springs
Hello all,
Part 2:
i've changed the device and now i can drill a hole exactly in the middle of the leave spring
one like the other:
Best Regards
Wolfgang
Old 05-02-2014, 06:50 PM
Trackerman Trackerman is offline
Trackerman is on a distinguished road
Sailbagger,
Nice work. One question can you show how you obtain the set in the spring. Set being the curve.
Thank you
Paul
Old 05-02-2014, 07:49 PM
Finster's Avatar
Finster Finster is offline
Nice jig. Looks quite useful. I may have to steal this idea.
Brian
Old 05-03-2014, 03:40 AM
Seilbagger's Avatar
Originally Posted by Trackerman View Post
Sailbagger,
Thank you
Paul
Hello Paul,
i hope to translate it correct: While cutting the bronze with scissors, it curls. I turned the strpes manual in the correct Position, only little and fast work.
Best Regards
Wolfgang
Old 05-03-2014, 06:05 AM
rsd53 rsd53 is offline
rsd53 is on a distinguished road
I really like what you have done. What thickness of bronze are you using, and what material are you using to hold the springs together?
Rob
Old 05-03-2014, 08:42 AM
kaptain Jack's Avatar
They look nice as a static part,but will they spring,or simply bend under pressure?
Old 05-03-2014, 10:48 AM
Seilbagger's Avatar
They have better function than the parts you can buy
Best Regards
Wolfgang
Old 05-03-2014, 10:53 AM
Seilbagger's Avatar
Rob
Hello Rob,
the thickness is 0,5mm. The parts for hold the springs together is in every windshield wiper under the rubber. Naturally i have used an old. The parts a pressed with aid of a vise.
Best Regards
Wolfgang
Old 05-03-2014, 11:52 AM
Seilbagger's Avatar
Hello all,
the function in motion:
https://www.youtube.com/watch?v=Iea6NgIpvnA
Best Regards
Wolfgang
Old 05-03-2014, 06:51 PM
Sailbagger,
Yes you have translated correctly, thankyou for the response. The vid of the spring set flexing is excellent.
Cheers
Paul
Old 05-03-2014, 08:03 PM
Lmackattack's Avatar
those springs are very cool and look real! . I would like to build some for the rear of my trucks as the stock Tamiya are way to soft for hauling a trailer load of dirt. While on the topic of springs I have noticed that if you use just a single Tamiya leaf for the front axel it will allow it to operate better when going over uneven bumps. it also helps with traction as the frame does not twist as much and keeps weight balanced better on the drives...
Old 09-19-2020, 05:09 PM
I know this is a 7 year old thread but if your still around how did these bronze leaf springs hold up... Do you still make them like this ?? I think I'd like to give it a try if they have held up well.
