Old 05-03-2014, 04:59 PM
thercfreak2012 thercfreak2012 is offline
thercfreak2012 is on a distinguished road
Default Re: CAT330D-L full hydraulic
Nice work mate
Old 05-04-2014, 05:59 AM
Erik79's Avatar
Erik79 Erik79 is offline
Erik79 is on a distinguished road
Smile Re: CAT330D-L full hydraulic
Thanks everybody!
@SmallHaul: Yes, the patience is a "must" for this kind of works on manual machine. The hydraulic motors has needed a lot of study too. Hope with the new CNC components it works well and has a lot of torque!
Now some other photos of the machine.
The arm painted with epoxy primer....
Is made by aluminium sheets of 3 and 1,5 millimeters brazed together, so is box-shaped.
Old 05-04-2014, 01:44 PM
Stuart's Avatar
Stuart Stuart is offline
WOW this is superb! will be watching this one for sure. What scale is it in? or did I miss that bit?
Stu
Old 05-04-2014, 03:08 PM
Wow! Beautiful machining. Hydraulic track drive motors too. Very cool. Everything looks great so far. This will be a nice build to keep an eye on.
Old 05-05-2014, 06:05 AM
Erik79's Avatar
Thanks Espeefan and Stuart.
@Stuart: it is in 1:14,5 scale.
Here some photos of the chain rollers in stainless steel...
Old 05-06-2014, 04:07 AM
Erik79's Avatar
Hi everyone, now i got the chain links just molded.
I put some of them under the model to see how is the first impression...
I have to drill the holes, to turn the pins and the rollers and to assemble all the parts with e-clips. Another patience work....
Old 05-06-2014, 06:41 AM
RCKiwi RCKiwi is offline
RCKiwi is on a distinguished road
Exceptional workmanship indeed. Keep the photos coming!
Old 05-06-2014, 11:29 AM
anthonymcc's Avatar
anthonymcc anthonymcc is offline
anthonymcc is on a distinguished road
Flawless machining and build work.
Old 05-06-2014, 12:57 PM
JLTrinity JLTrinity is offline
JLTrinity is on a distinguished road
Wow, amazing work. Congrats!
Old 05-06-2014, 10:05 PM
cosworth34677's Avatar
wow that thing is crazy!!!! great work
Old 05-07-2014, 11:34 AM
Awesome job. Keep up the amazing work.
Old 05-07-2014, 06:03 PM
Erik79's Avatar
Thanks a lot to everybody, i'm happy that you enjoy the model.
In the next photos the chain completed, only one side.
See you soon...
Old 05-07-2014, 07:18 PM
avel avel is offline
Wow! Nice tracks!
Old 05-07-2014, 07:57 PM
This is looking so great! Did you cast the track pads yourself or????
Reg
Old 05-08-2014, 06:51 AM
Erik79's Avatar
Hello everyone,
@ Rcp57: I have designed the scaled model of the pads on 3D CAD, built the model piece on my milling machine and find a factory that made the copy of the model by molding.
@Thuangs: The real machine has the options between 700mm, 800mm, and 850mm. This is the 800mm and in 1:14,5 scale is around 54,5mm (half millimeters lost due to the molding retirement). The inside Groove of the links is made for a wheel of 6mm and so is 6,5mm. Pins diameter is 3mm.
My greets,
Enrico
Old 05-08-2014, 07:01 AM
Ramon's Avatar
Ramon Ramon is offline
Ramon is on a distinguished road
Hi Erik,
Really nice work, I like the precision of your CNC parts. The hydraulics looking good as well. Do you have a drawing/sketch of the hydraulic motor?
Old 05-08-2014, 08:09 AM
Erik79's Avatar
Thanks Ramon, but nothing that you have seen in the photos is made by CNC. Is made by manual lathe and mill. The part made by CNC is only the coupling of rotor/stator that i am waiting for complete and test the hydraulic motor. This coupling has a complex profile that can not be built by manual mill and the profile i have used for the first construction, only to test the overall working, is approximated and manual milled.
The motor is of the orbital type, has a 7.8 cubic centimeters of displacement, the distributor valve is of the disk type and the motor has no drain.
For now i still have to definitive test it and prefer to not publicize the particulated drawings, i'm sorry.
Old 05-08-2014, 03:47 PM
Very clean build, if I were you I would make holes in the track pads where the dirt can escape from the idler and sprocket, if dirt packs up it can make the tracks skip or slip off, just a heads up!
Old 05-08-2014, 05:29 PM
Erik79's Avatar
Thanks for your intervention Azonic, in effect the problem that you analize is well known. The reason for the decision to don't make that holes is mainly structural: the shoes are made to be as strong as possible and the holes in that position makes the middle section a little too thin. This is the same reason why i have choosen to don't make the holes that pass through the flank of the chain. Instead i have changed a little the design of the chain links in another zone to minimize the problem that you notice: if you carefully watch the point in which one shoe is coupling and slide with the following one (in the bend the chain makes around a wheel) you can see that there is an opening that (i hope) helps the dirt to not stuck in. In the past set of photos this detail is not so simply to observe but in the next you will clearly see it. Other further solution to the problem could be the lowering of the profile of the teeth on the sprocket.
Finally ther is a thing to say about this problem: the typical weight of this reproduction models is so low to amplificate a lot some limits in the functionality of the chain-shoes, so it seems to be a must to provide to a spring that makes the freewheel slides back to prevent the lock of the chain in the case a little stone is stucked in between.
I hope to have made the right choises and the chain works well, but i'll can say that only after some tests.
Any other constructive critical intervention from you and each others will be greatly appreciated.....
Bye!
(sorry everyone for my english, i'm not a mothertongue like you can see)
Old 05-09-2014, 02:09 AM
ricm ricm is offline
100% insane build - AWESOME......
stunning
