Old 05-26-2014, 11:20 PM
heytruck heytruck is offline
heytruck is on a distinguished road
Default Turn signal relay
Without an MFU what can be used to make the turn signals and 4-way flashers flash?
Old 05-27-2014, 01:00 AM
ricm ricm is offline
Default Re: Turn signal relay
you can get indicator switch units which fit between the receiver and the steering servo - a chap called 'mrrcworld' makes and sells them on eBay, I have used his products before no problems.
Either that, or you could make your own using a basic flasher circuit which is switched using a lever from the steering linkage. This is how Tamiya originally did it with the now obsolete Electrical Unit Set (#56501)
http://www.tamiya-model.co.uk/shop/t...er-p-6327.html
