Go Back   RC Truck and Construction > RC Truck's Kings of the Road > Australian Rigs & Roadtrains
Australian Rigs & Roadtrains A place for aussies to show off their unique truck configurations.
Old 07-14-2014, 05:32 AM
STI-REX STI-REX is offline
STI-REX is on a distinguished road
Default Half way there B-Double my first trailer build
Well 5 weeks ago I inherited a 56318 Scania R470 4x2 metallic edition in a trade for a Quadcopter
So I decided to go the whole hog and build a B-Double for it
so from this lot
To this lot
First up R470 prime mover soon to be 6x4 flat top and full trailer
shown here hooked up to the the "B" trailer
And now the almost finished "A" trailer
More to come as I get time I currently have a brand new Scania R620 kit with MFC and a new 2.4 ghz radio sitting on the bench to be assembled this weekend (Mr's is out of town so lots of peace )
And I just got a 2 axle dolly and assembled a flatdeck trailer to make it a sort of 4 axle full trailer
And I have ordered some gear to convert the R470 into a lwb 6x4 flat deck truck to pull the full trailer
I have been into R/C and Tamiya models since I was 5or 6 (now 46)
But this is my first ever semi trailer build so still plenty to learn
I am also an ex Driver having driven for BP and Mainfreight whilst living in NZ operating Tankers, Sideloaders (container swinglift ) along with curtainside B-Doubles and truck and trailer 8x4 with 4 axle trailer for over 20 years
Now off the road due to disability from falling from truck I stuffed my right shoulder and elbow 2 surgeries and many more to come
Old 07-14-2014, 05:53 AM
bigford's Avatar
bigford bigford is offline
Default Re: Half way there B-Double my first trailer build
great start to a cool build.. one question why do you guys use this set up
instead of converter dollies. seems like you lose half of your trailer for each unit
most multi trailers here in the u.s. are doubles or triple pups
Old 07-14-2014, 06:21 AM
This type of setup is small for Aus at 25 mtrs total length 1:1
But it needs to be taken into very tight spaces to load and unload and will be backed into and out of customers premises 10 or more times a day on metro work
also negotiating some of our roads 2 x long semi's on converter dollies would not make the turn in the metro areas
In the Outback (desert or mud hole seasonally dependant) they use some converter dollies on the Roadtrains but they do not generally come into big cities
Coupling over axle sways less than coupling after axle and is more stable under emergency braking (less jackknife prone )
Old 07-14-2014, 07:01 PM
datsbig datsbig is offline
datsbig is on a distinguished road
It's a sheepish load you've got on the B trailer ;-)
Great looking build on that A trailer. I'd almost pick it as perfect for my king colour scheme.
Old 07-15-2014, 01:51 AM
I got my rails From some one in Caloundra on the sunny coast
Old 07-15-2014, 03:19 AM
Were the rails pre-cut and drilled for a lead trailer?
Old 07-15-2014, 04:51 PM
They are cut and mostly drilled
The main difference being is that the B trailer is 870mm long so is a bit longer than a flatdeck semi
the deck on the A trailer is 440mm
to make a 3rd axle you would need to cut a set of springs almost in half (dremel with safety glasses)
Old 01-19-2015, 11:17 PM
Looking great :-)
