Old 07-20-2014, 12:54 PM
Default Re: Volvo A40F
I started to make the frame
Old 07-21-2014, 12:08 PM
I test fitted the bogie to the frame. I don't have the new middle axle yet to see if the drive shaft have enough room
I think I start to make the a-frames front end attachment next. I going to use a ball joint there so that the bogie and axles can move freely.
Old 07-21-2014, 03:44 PM
modelman modelman is offline
This is a nice build you have started. All the work is top-notch, just like your other builds. I enjoy watching how you design the parts and then machine all the pieces. Great work!!
Old 07-21-2014, 09:16 PM
FullMetalFab FullMetalFab is offline
FullMetalFab is on a distinguished road
Differently going to have to take notes from the thread for when i start building one of those dump truck things. Very nice work, i will enjoy seeing how this comes along.
Old 07-23-2014, 05:01 AM
Originally Posted by Pippoe View Post
Beautiful truck so far!! Applause!
Using that new axle should make the truck much more durable. Since the shaft passes through the differential of the middle axle the current axle has to withstand the load of both axles.. The axle with the bypass (provided it actually is a bypass) distributes the load equally onto both axles. Should be much better for the drive train..
Cheers
Pip
That's true Pip.
I just got the the new middle axle and it really is a bypass axle
Old 07-23-2014, 07:35 PM
rc entreprenøren rc entreprenøren is offline
rc entreprenøren is on a distinguished road
Hello Ari.
As always .. excellent work.
fast it is going to
Love the way you produce suspension on. quite similar to the original machine.
Looking forward to further build pictures ..
Old 07-24-2014, 01:15 AM
The new middle axle does the trick, there's plenty of clearance around the drive shaft now
Old 07-24-2014, 12:39 PM
I got the rear axle a-frame ball joint attached to the main frame
Old 07-24-2014, 01:03 PM
jazza's Avatar
jazza jazza is offline
jazza is on a distinguished road
Oh! I can't wait to see your next part
Old 07-24-2014, 02:09 PM
JeanPierreBussio JeanPierreBussio is offline
JeanPierreBussio is on a distinguished road
WHere you buy these axles? Or did I miss that answer already ;-)
Old 07-24-2014, 02:24 PM
They are from Rigidrc :http://rigidrc.com/shop/27-axle-housing
Old 07-24-2014, 02:31 PM
I was waiting to see how that A frame was to be connected to frame... can I see a horizontal view plz?
We cdns still blocked from seeing the rigidrc site.
Old 07-25-2014, 01:12 AM
Can some of you Canadians try the Rigidrc site now, I ask them about it and they said that they will fix it
Old 07-25-2014, 10:37 AM
I can see it now!
Thank you very much Ari for contacting them.
Old 07-25-2014, 11:48 PM
DADSGARAGE's Avatar
Fantastic job on the build so far!!!!! Looking forward to seeing more....keep up the excellent work!!!
( I wish I had your talent and skill )
KP
Old 07-26-2014, 09:15 AM
KP
Thanks buddy , I've seen your work and I can say the same for you
I got the axle cross stays attached to the frame.
The frame is still missing the sheeting that covers the frame rails and where all the brackets will attach.
Old 08-03-2014, 10:47 AM
I got the frame bottom plate an few other parts done this weekend
Old 08-03-2014, 12:56 PM
well done done , Ari
Old 08-03-2014, 01:05 PM
Hello ari.
impressive work again.:-) This is getting more and more fun to watch.
I have sendt you 2 PM... do you have full innbox. ????
Old 08-03-2014, 02:10 PM
Originally Posted by rc entreprenøren View Post
Hello ari.
That's strange, I haven't received any. There is room in my inbox
