#81
Like you said..strange.. but ive tryed again. ..:-)
#82
Hello Ari,
I should have expected this. Have been away from the forum for just some months and here is an almost half-finished (well, ok, some 20% maybe) ADT from you. Awesome as always!!! Excellent choice of model IMHO. Would build one myself if I wasn't too busy already. So that´s why I ask you where you managed to get the drawings I see in the background in some pictures? Seems to be from the spare parts catalogue. Will follow this amazing build closely. Stefan |
#83
those drawings are from Volvo Prosis Workshop Manual & Parts Catalogue DVD. There are plenty of them for sale on Ebay: http://www.ebay.com/itm/Volvo-PROSIS...item2a41a252af
#84
Thanks for the link, Ari!
Stefan |
#85
#86
#87
I started working with the front axle. First I made the a-frame
![]() The front axle is mounted to the frame via a 3-point mounting system, consisting of rubber springs and shock absorbers. ![]() ![]()
#88
#89
Hello, fantastic all I congratulate you construction
#90
It's looking more crowded with each update! Have you had to do any re-engineering yet?
#91
Intresting work! I like it very much.
I'm waiting other photos, my compliments. Enrico |
#92
I was able to start making the front frame and I also got the front axle mounted with the rubber springs.
As Lil Giants earlier said, it's getting more crowded each update and I can see now that there wont be much room lenghtwise for the drop box and drive shaft to the front axle ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#93
On the front axle and gearbox...
- flip the axle over so the input is at the front - may still have a problem with getting the drive to the rear though (not to mention if it goes backward). - run the drop box in the rear, requires two drive shafts across the articulation joint. not very scale options... but if you get pushed... I am seriously jealous of the work completed to date... wish I had the skills, tools and time to do it. :-) Cheers, AP |
#94
now this is talent. all hand made and no 3d printing
Very nice and clean build
Specializing in VW beetle water pumps! RIP FREDDYGEARDRIVE |
#95
![]() I made some progress with the front frame and also got the frame link bearing housing machined. ![]() ![]()
#96
I started to make the articulated joint or rear hitch as Volvo calls the part. I will make it in steel and in one peace. It will be quite complex part to machine, will see how it turns out
#97
#98
It looks amazing! Great job!
#99
wow amazing build ..
#100
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
