#341
Perfect form Coop!! there's 12 inches of snow on my track now or I'd be roostin it!!
#342
I know how to get you riding but still foil Mario's plan! I "might" have a few hoped up Honda 50's kicking around and the track for riding them is right in front of my house. This way we can all ride and I can keep tabs on Mario...lol
#343
Hey Cooper, use that drill, to help you figure out conveyor rpm.
Cheers, Neil. |
#344
Great work on the rollers RW, now set printer replay to "100". (Seriously)
What's the width of the middle roller? I intend to go with 12v gearhead motors @75-100rpm. 12v deep cycle battery, take it anywhere. ![]()
#345
Thanks, that's the rpm I was thinking too. Yea, I realize I need rollers, rollers, rollers!!! I don't want a vibrating conveyor!! What I have in mind for power is to have everything running on 12v dc. Out back I have several 110v dc outlets that I could plug into while at home. By operating off 12v dc I will be able to have that option also if I set up somewhere remote. I haven't yet checked if my low voltage transformers work but pretty sure they do. Going to set up something with banana plugs, so connecting to transformer or battery will be simple. Now the hard part is if I want to build a swing assembly to dump material in seperate piles. And to have an elevation mechanism.
#346
Oh, middle rollers are 1.85" and ends are 1.2". Belt is like 3-7/8" wide by 4-1/2' long.
#347
Yes, I'm pretty sure Coop could be busy making some of them, there rollers for us non 3d printer having people...and making some money to buy the wife that new dog come spring...
#348
#349
![]() You want some? Might take a while to print. One roller bracket takes 44 min to print, then cutting some 1/8" shafts, and about 2min on the rollers. The rollers are made from 3/4" acetal, I didn't print them. Had a couple feet of acetal/delrin laying around. Speaking of have to get more, I purchased those off eBay, like $5 a foot of 3/4" stock. I looked at McMaster and other supply places and almost half price. So now knowing I need more I might try and find an even cheeper material. Mario gave me an idea of using wood with a cheep Teflon sleeve. Always looking for a cheeper alternative way. Because I now have to think of feeding another mouth!!! Lol!!! I owe ya reg for hooking me up with the awesome dump bed!! Had some time today so me and the psycho, totally defendant on the wife, slobbering on all my stuff, wouldn't leave me alone, pooping in my sandbox, Great Dane played in the pit. I tried to take some video but my "helper " kept knocking over the tripod. And got the big cat out. For some reason one of the tilt servos quit working. Pretty good servo, hitec, it was working fine for a demo when the I laws were here but stopped as soon as I got to pit ![]()
#350
![]() ![]() ![]() Thinking of you joe, today was pretty warm, 40 degrees and sunny so I had to take advantage of it. And ground isn't frozen. What kind of weather you have? When does ground warm up in your location? Farthest north I've been is Montreal or north of Vancouver , whistler.
#351
http://youtu.be/w20XKVuQqFQ
She might be over weight, it's pretty wet material, no problem with lifting!! I'm very happy with it reg!!
#352
#353
Snow on the ground since early November, temps vary from -30 to +8C, December has been quite mild. Last couple Springs have been quite late, last wk of April - 1st week of May before the snow is done for the season.
#354
I'm drooling RW ! Those 3D printers are amazing and also unfair to those of us without one.
![]() ![]() That's going to be one beautiful conveyor. Nice work so far. I agree about trying to keep projects like this cheap and simple. That's half the fun trying to use what's around you. I also like trying to keep the weight down. If I have to carry this stuff up from the basement a lot, I don't want it weighing a ton! ![]() |
#355
A good comeback!! ![]()
#356
I decided to use some flat top bracing in between rollers. If belt droops any it will slide on metal flats. Well that's the plan
#357
#358
Hey Cooper, surface prep! you can wire wheel or preferably a sanding disc, and take the coating off to bare metal. Just don't breath the cadmium fumes, they are toxic!
Cheers, Neil. |
#359
Your two main rails appeared to be galvanized which will explain the white looking residue and while welding the gas it puts off will contaminate your shielding gas from the welder. I am assuming you using a MIG welder and you would have to remove almost all of the coating and possibly acid wash the parts to get the most of it out but if it is good galvanizing you won’t get it all out.
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
#360
Thanks guys, yes I guess prep would have , or should have been a first step instead of last step;(. I do have somewhat of a ventilation system, at least gets gas/fumes to the outside. Garage door opened a crack with window open with fan. Cold air rolls in from outside and warm air gets pushed out through top window. In wintertime it works pretty well. I figured with the white residue it was galvanized. I use to seeing galvanized stuff looking ruff and silverish. Again my ignorance will be my teacher for next time
Currently Active Users Viewing This Thread: 22 (0 members and 22 guests) | |
Thread Tools | |
Display Modes | |
