Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
#181
I had to come back for another look. Good stuff! Where did you get your shackles, or did you make them? Dan
#182
I bought the shackles from amazon, ha, ha! They are Steel D Shaped Shackles, 5/32" (4mm) thick, 5/16" (9mm) inside diameter. Kerst |
#183
I got inspired by this crane again and started to add the jib.
There is a fixed jib and a luffing jib available and they share many basic parts. So I started to make some of the parts that can be used for both. initially i will make the fixed jib and later the more complicated luffing jib. ![]() ![]() ![]() Kerst Last edited by kerst; 07-02-2019 at 06:19 AM. |
#184
Thank you for the kind remarks!
I made some good progress these past weeks. ![]() ![]() ![]() ![]() Next is a 7 meter insert. Kerst |
#185
I'm really digging the booms, and the jib boom connection in a pretty slick set up
#186
I decided to make the luffing jib as well and I am almost done. Only the pendants need to be made.
![]() ![]() Kerst |
#187
Awesome work, as usual! That's a lot of fitting and soldering and machining and patience and all the other stuff it takes to make a complicated system like a crane.
![]() ![]() ![]() Ken
Big iron is awesome! |
#188
Finally I put it all together. Getting all the bits together took quite a bit of time and I had to make a few adjustments to the winch for the luffing jib.
yesterday was the day and it worked nicely. I am fairly pleased with the result and how easily the crane handled the luffer. It is testing time now and I am making a list of all the small adjustments that need to be made. ![]() ![]() ![]() I am looking forward to the Cabin Fever Expo in January 2020. Then I can show it at full height! Ceilings are in the way at home. Kerst |
#189
Looking good as usual Mr. Crane Guru. And it's ready for Cabin Fever also! Let's put it to work and have fun, got some beams in mind.........can't wait to see it up and running.
#190
Looking forward to seeing the photos of it at full height and with Bo’S beams!
#191
GREAT build! AWESOME workmanship!!
FabOne NW Ohio |
#192
Wow that looks great!!!
I can't wait to see a video of it luffing and moving something
#193
Nice work
#194
Kerst, Just wondering how much weight you can lift safely, I'm making stuff to lift, don't wanna overcharge your lifting chart.
#195
Up to 20 lbs!
#196
I managed to get the paint job done during the Thanksgiving break and put it all together for testing. There is one back stop missing.
Here it is fitted with the fixed jib: ![]() ![]() ![]() And here the luffing jib: ![]() ![]() ![]() Here it is lifting a test load of 14 lbs: ![]() ![]() And here with only 7 lbs: ![]() Kerst |
#197
Simply stunning! I've got some 4-8 and 12lbs. Ready to lift. You might need a spreader 4" by 20"
#198
Wow, Please don't max it out on one of those picks.
#199
Wow. Jaw droppingly awesome
Looks and performs amazing if you've got a 14lb load on the 1/24 crane!
#200
Thread Tools | |
Display Modes | |
