#181
You my friend are incredible
#182
OUTSTANDING!
#183
Wow, exact detail, right down to the ball joint! Nice!
Nathan |
#184
beautiful work
Jarrett |
#185
Thanks fellows! Have some "making of" pics to add:
#186
Wow.....the workmanship on this is exceptional!!! Remarkable amount of work and skill going into this build, the attention to details is inspiring!!
#187
Hello guys, I see an update is more than overdue, had to go to the fifth page to find the thread again.
Having spent a long time making some as-much-scale-as-seems-possible 45 degree angled fittings I couldn´t wait finishing the 90 degrees ones, and finally had the circle drive tested without them only last week, although I finished the valve already last April. With the glide bearings still missing, the tooth wheels jam in one direction, but funny enough hardly in the other, as you can see in this video. Last edited by Stefan; 11-08-2017 at 01:20 PM. Reason: Link repair |
#188
Absolutely fantastic work Stefan
![]() ![]() ![]() ![]() ![]() Last edited by titandigs; 01-25-2015 at 07:21 AM. |
#189
That is just amazing!
#190
#191
@ Paul, Ap, Pontiacmann: Thanks! Glad you like it.
Now to the moldboard. Started from a stainless tube with 3 mm wall thickness. The radius of the tube was only slightly smaller than needed and to my luck it widened up to almost exact scale radius when the cut released the inner tensions. The upper edge has a non-radiused portion, so a 10 mm by 3 mm strip was added. The real moldboard is recessed along three sides for the cutting edges as you can see here. The recesses are apparently forged in a big press, so forging was one of the build options considered, but in the end I opted for a combination of adding parts to the edges and milling and grinding out the final shape. First, the ends were bevelled. Stefan Last edited by Stefan; 11-08-2017 at 01:24 PM. Reason: Link repair |
#192
WOW!!!
![]() ![]() ![]() Absolutely one of the best builds to date on the forum.
LYNN |
#193
I have to agree with tc1cat you are so skilled it's un real. Wish I had just 1/10 of the skill you have been watching very close. Keep up the good I am sure many will be watching also
#194
Man you definitely are disciplined in your work!! I have a hard time when I have to change drill bits!!! Skill and dedication are paying off, build looks awesome. Looks like you got a 1:1 to keep the details in sight!!
#195
Stefan your skills and thought of how to preform the operation are very impressive. Thank you for sharing you skills and thoughts with us. Ed
#196
Thanks for the great comments! Think I´ll be able to post some more pictures the coming weeks.
Stefan |
#197
Impressive video and photos of the work you do, Stefan. I think Your work is inspriring for most of us. Looking forward to coming updates!
Dan |
#198
Terrific project. Great photos.
#199
Wow Stevan,
This is a FANTASTIC build thread and words can't discribe how great the level of skill needed to complete this task well done keep up the great work ![]() ![]() |
#200
Thanks for the recent comments. Now, to the bevelled ends the recessed portions were separately attached.
Simple jig ![]() Some tig spots. Before and after hard soldering. Stefan Last edited by Stefan; 11-08-2017 at 01:28 PM. Reason: Link repair |
Tags |
1:8, grader, volvo |
Thread Tools | |
Display Modes | |
