Old 02-28-2015, 10:37 AM
Buster's Avatar
Buster Buster is offline
Buster is on a distinguished road
Default Re: I need radio help please!
When I connect the receiver first and then turn the TRX on, the pump turns the wrong way.
When I first turn the TRX on with the throtle switch in the "on" position the display shows an switch error, when I put the switch in the off position then the message on the display disappears but when I connect the receiver and switch the throtle switch to the on position the pump runs in the wrong direction.
If I start the TRX with the throtle switch in the right (off) position and connect the RX the pump motor then turns in the right direction.
I think this is the correct startup procedure.
Erwin
Old 02-28-2015, 07:46 PM
Chi-Noos Chi-Noos is offline
Chi-Noos is on a distinguished road
Erwin
I know it sounds dumb but is the white wire in the position closests to that of the main portion of the rx?
