#141
Ari ur work is top notch u have some serious talent, u make me push my limited skills to the max and I thank you for that, I'm currently building a CAT 374D like yours it gave me the inspiration and a lot of the ideas I hope u don't mind, I was wondering if u are happy with the hydraulic pump and motor, valves etc u used or if u would change them.? I've been looking into premacon pump and valves? But I just can't make my mind up, at the pace I build at I'm not going to post any pics on here until I'm almost finnished but I would like to send u some pics to see what u think would u have an email address u could pm me, ?
Again thanks for the inspiration and sharing ur knowledge, Regards Steve |
#142
#143
Very impressive work!!! It is truly a master piece! How long have you been a machinist?
#144
Hi guys
![]() It's been quiet with the A40 as I've been making some parts for my friend for several weeks now, but now I got some time for this too. I started to make the drop box. I was originally thinking that I make it with two larger gears, but I soon noticed that there's not enough room between the steering cylinders. So I have to use three smaller gears to make it fit. ![]() ![]() ![]() ![]()
#145
Keep it up Ari. Fantastic skills.
You are an inspiration to many To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , you will not be forgotten. R.I.P. FGD Work Hard, Play Hard! Never Forget- 343 |
#146
You are an amazing builder, that is a work of art!
#147
Good choice of axles, I am a big fan of these which is the best engineered axles in the Tamiya scale I have studied.
It is a special tool needed to make the internal slots in theg ears. Can you show a picture of it? I imagine it is a quite expencive tool? |
#148
It's not that expensive: https://www.wabeco-remscheid.de/keil...adeln-hss.html You also need some kind of arbor press to push the tool through the gear. ![]()
#149
Hi Hemi any chance you can tell me where you got the drawings from thanks
#150
The drawings are from the Volvo A40 parts and repair manual and from the brochures.
#151
I got the dropbox attached to the frame and also got the 3-speed gearbox mounted. The gearbox is made by Veroma modellbau.
I also made a short video of the drivetrain running: https://www.youtube.com/watch?v=NOV8...ature=youtu.be ![]() ![]() https://www.youtube.com/watch?v=NOV8...ature=youtu.be
#152
Wow looks smooth. Keep.up the great work
#153
WOW!!! every square inch of this screams masterpiece. If you don't mine I have a few questions, How did you attach the rubber bumpers for the rear suspension to the aluminum? How are you cutting the thin sheet metal? with your mill?
Again you are an amazing machinist. Skilled craftsman are becoming few and far between as the years go on Seeing this enforces the fact I plan to make my son learn a hands on trade as well as a college degree. I believe there will be a day when a college educated man will come 2nd to a well trained tradesman. Last edited by crawler07; 03-18-2015 at 08:51 PM. |
#154
#155
Just make a tool in the channel width and entering decimal measures to the channel. Note:. Power off. |
#156
I do have a lathe, but those keys I use are only 2mm thick and I'm not sure how well a self made high speed steel tool might last on that. But anyway with bigger ones it does work ![]()
#157
#158
Nice!
#159
#160
Ari very nice job. I like the straps you put on the cylinders to hold the lines in place. The rest of your pluming looks great keep up the gpood work. Best Regards Ed
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
Thread Tools | |
Display Modes | |
