#661
#662
I was wondering why you had to reach down and unlatch the fifth wheel in the video you did, I had a hard time not making a comment at the time
#663
Do you have a rpm tester(mechanical or electronic)? 4500rpm
And I set the pressure to 18bar, that's plenty of power to dig loose soil with 14mm pistons & the 42lbs model won't move. And no mix on the valves with the pump, just turn the pump on & leave it to run one constant speed. Caterpillar controls are bass ackwards, JD controls are best. ![]() ![]()
#664
Blahh blahhh blahh JD controls,,,,,, lol!!! I'm a cat man!!!
Yes, I was planning on having the pump run a constant speed. I do have it on a switch for off/on then use one of the dial pots to change speed for different situations. I haven't messed with best pressure yet, I know the cylinders, hoses and such will handle much more pressure than needed. I didn't really understand exactly the flow/pressure of these pumps so figured get the bigger one. They are really great pumps but I should have got the smaller flow one. Couple things I've been wanting to get I don't have, one- rpm sensor and two- a servo tester. Both aren't expensive and I'm bass ackwards when it comes to that stuff, don't hesitate to get some expensive tool but contemplate on the cheep small stuff?!?! Go figure! I'll let ya know where I end up with rpm and pressure /relief. Thanks joe.
#665
![]() ![]() ![]() Got the truck servo hooked up. Pic s above are the hitch locked and unlocked. Didn't try it with truck yet. ![]()
#666
Looks like should work fine. Time for some armchair truckin'
#667
Almost, it works pretty good. I started taming the excavator rx controls. Before I did that I had to drive up on trailer with the ex, side boards are a must !!! Not much room for touchy controls driving up the neck.
Hey joe , I just sent ya an email about pump if ya have an idea would appreciate it ![]()
#668
http://youtu.be/ZQ2fhhMkTsY
Here is a video of a problem I'm encountering. The valve center has been established and messed with so it's not drifting because of not being centered. I completely disassembled the cylinder to check piston and shaft seals and replaced with new. When I reattached the cylinder I worked all air out with temporary lines hooked up into glass of oil, then turned on pump to squirt oil out of lines before attaching to make sure air was purged completely from system. I am currently hooking another spare cylinder up to valve to completely eliminate the lines, hard lines, and cylinder in question to see if it does same thing. Trying to trouble shoot everything before tearing apart valve. As that's the last thing I want to do, I've never taken one apart and don't know about seals inside or what sizes let alone having a spare if it isn't damaged and I damage it from removal. In the video you can hear the squealing I'm referring to. I originally thought it was gears between motor and pump but now I'm thinking it is just oil being pumped. When I started it up this morning it was gone but returned. And if I'm getting air sucked into system I would surly think oil would be leaking out also. I have no leaks anywhere, valve, hoses, fittings, cylinder, all dry. What do you guys think? Valve seal? I'll post up again on results of swapping cylinder out to see if it does same.
#669
I was having a similar problem with the bucket cylinder on my loader and it turned of to be a bad o ring on the piston letting the oil blow by. It wood move but had no power and I had no leaks on the cylinder at that time. Hop this helps
#670
That's what I was thinking originally, I replaced piston seal and it still does it. In the process of using a different cylinder to see if it does it with that one. I didn't check piston , possibly I made a mistake in the manufacturing of the piston. But when I had it apart I worked the piston in the cylinder and it created a lot of resistance when line was sealed so I think the cylinder is good. ??
#671
Cooper as a quick guess I would say it's the piston seal or o'ring. Take the cylinder apart and my bet is you'll find the culprit. If it was a valve seal you'd have to push all the oil out of the cylinder back through the valve to the tank. You're not getting that much resistance so it's a short bypass meaning some where in the cylinder.
Also pretty sure it's the bypass valve that's making all the squealing noise too. That's why the pitch changes with speed, it's the volume of oil going through it that resonates the relief spring and ball! Rob |
#672
I had the same issue with my 4200.
it would do the same as yours dose in the video. I spent ages on the valve , centring it and scratching my head. I had a spare new ram , swapped it out and problem gone, stripped old ram and found the seal worn and letting oil flow around it, ram would move but under load it had no power. cheers andy |
#673
Ok I swapped stick cylinder out and used the one I had for the failed dump project. No way was I going to hold that from extending or retracting by hand. And when valve centered I couldn't move it. So thanks for the input guys, I am pretty sure it's not the valve. No on to next thing, maybe I had used the wrong piston to start with. I know I made a few to try and dial in the right size. Not like I could find directions on what diameter piston to make
#674
My pump sorta sounds like with no valve movement, but my pressure is set much lower than yours. You're at 350psi, I'm at 252psi.
#675
Combination of two things I think. Piston is not right size to seal well with ring. And the piston is allowing oil to flow from bolt holding it on, and then between piston id and shaft that piston slides over. Basically the bolt holding it on was loose and those washers are bad. And I m pretty sure I grabbed one of the wrong pistons when assembling.
#676
Ok put the cylinder back together with original piston, this time I removed the two washers I had on end and replaced with washer with rubber backing. Will prevent any leakage from bolt hole through piston. And it works now!! And to think I was thinking of getting into that valve assembly. Thanks for the input guys, helped a lot!!!
#677
Haven't had any stupid animal pics lately so,,,,
I don't think I impressed these two worthless clowns, only reason they came out to garage is wife is away and it's feeding time. !!!!!! ![]() ![]()
#678
Cool I'm glad you got it fixed so we can see some good vids that shovel looks amazing by the way good job
#679
Thanks, I'm tempted to go get a skidsteer scoop of screenings and dump in garage floor. Snow on ground again and weather looks to be cold again
#680
I would just put some plastic down and go for it. Then again never mind the plastic and just leave the dirt there for winters to come!!
