Old 08-21-2015, 06:21 AM
Default Re: JBC limited NZ
loader cleaning a path to the dig site
a lot of roots to deal with, will need the excavator with ripper to do the job.
we will see how smart this site is.
may be back to the gravel pit , time will tell.
http://youtu.be/HfOAtP6AMdk
cheers andy
Old 08-26-2015, 01:21 AM
had enough of tree roots so, the dozer was fired up.
Im thinking a little manual spade work is also needed.
video time
http://youtu.be/B1gOnnFDEbc
cheers andy
Old 08-26-2015, 11:11 PM
had a little spare time so I made some ears for the dump truck,
Had some stainless tube lying around so a little welding and job done.
cheers andy
Old 09-03-2015, 01:13 AM
more average weather , so moved the screening plant and sorted out where the crusher plant will sit.
ran a few trailer loads and spread on new road.
and a quick video
http://youtu.be/E1NJe_013Xc
Old 09-03-2015, 04:37 PM
justin justin is offline
justin is on a distinguished road
Nice set up
Old 09-03-2015, 05:14 PM
Supermario's Avatar
I just read through your entire thread and noticed a few things. First, what a great fleet and a lot accomplished!
You asked me way back when what kind of run time I get out of a 8400.
Now that I have motor speed correct and some time at the controls, I get a solid hour and a half run time. I've got 2 of them. A .gens ace and a traxxas. The gens fits nicely, the traxxas is a little bigger and a snug fit.
I'm glad I did read through, I don't know where the heck I was but I had missed a lot of great info from you and Joe about radio settings for the 4200!
Thanks again for sharing and can't wait to see what's next.
Old 09-03-2015, 06:53 PM
im very much like you, no more building until winter starts again. LOL.
but having said that Ive always wanted to build a scraper to be towed by the dozer.
I have wheels and servos already so......
Old 09-04-2015, 02:39 AM
spent a rainy day in the pit .
https://youtu.be/iCCeWk2-h7g
cheers andy
Old 09-04-2015, 05:53 PM
I might have to look at the bigger battery option, thanks Mario.
I don't think Ive ever had a group family photo of the construction company,
I do know it has grown ever so slightly so I took a couple of pictures of my addiction.
Im going to need a bigger shed to store them in.
Old 09-04-2015, 07:08 PM
TRUCKMAKER's Avatar
Nice fleet!
Old 09-04-2015, 08:44 PM
jack van's Avatar
jack van jack van is offline
Cool Re: JBC limited NZ
wow you have a great fleet only thing left to get is a grader then you have it made congratulations
Old 09-04-2015, 09:29 PM
Supermario's Avatar
Family photos can really put things into perspective. That's why I stopped taking them. Lol.
I wonder what life would be like if I had a neighbour like you.
Probably be divorced in no time
Sweet fleet Andy!
Old 09-04-2015, 10:18 PM
divorced and broke LOL
showed the wife the photos, her comment was "I thought you had more than that"
So I better start building a few more.
going to do some googeling on scrapers for the next project.
cheers andy
Old 09-05-2015, 01:29 AM
jack van's Avatar
you would likely have the best back yard ever haha
Old 09-13-2015, 12:57 AM
I finally had a bit of spare time to play with the radio settings for the loader.
I've slowed the steering and bucket drop speed and it looks way better.
next on the list is main drive acceleration.
I want to slow that , but first I need to charge the battery again.....
https://youtu.be/a1kDuEwNe7U
Old 09-23-2015, 10:51 PM
I had a play with the hyd system in the excavator.
I pulled all the servos off the valves and centred them.
man I wish I had done this years ago, so much better and easier to control,
next on the list is to sort the slew motor, I have wear in the shaft and gear causing the wobbles when you stop the movement.
heres a quick video of the before and after
https://youtu.be/bLsvjFPvOsI
Old 09-24-2015, 04:43 PM
Supermario's Avatar
Running great Andy. I can't imagine operating with a drifting boom, bet your happy that's gone.
The sloppy slew. Did you try to snug the motor pinion up to swing gear at all? I've got excessive slop also but notice there is some adjustment possible. Going to wait until winter shut down before dealing with it.
And happy summer to ya!
Old 09-24-2015, 09:34 PM
cheers Mario,
yes much happier with the operation.
when I first got it I pulled it apart to see how it worked...
guess I put it back together a little wonky and always had to issue to a small degree.
I remembered reading something on this forum about centring the valves , gave it a go and discovered my mistake now it works great.
the problem with the slew is a worn motor shaft, too much slop between shaft and gear.
looks like the grub screw was always a little loose and scored the shaft, a new motor should fix the problem.
Im on a quest at the moment to get a 1969 Plymouth road runner and may end up having to get on a plane and visit the US to view a few . Have a guy here who dose this for a job ( friend of a friend) but our low dollar is making things a little expensive
Have been told by the Mrs that I cant load up the container with RC toys " your going for a car and that's all".....
not a hundred percent sure what she means by that but if any one can recommend a good model shop in or around Arizona I wont say anything....
cheers andy
Old 10-06-2015, 03:28 PM
had a little play time so I had another go at the radio settings for the loader.
so far I have dropped the steering speed by 50%
bucket drop also set at 50%
and main drive motor max speed is at 40% in reverse and 50% forward.
I could have just used the switch on the radio to lock the diffs and slow it down but I figured leaving it unlocked it would place less stress on the axels .
pretty happy with how this loader is working now, just that dam noisy pump....
https://youtu.be/RNuLJd2LVuo
cheers andy
Old 10-07-2015, 07:56 PM
osikasculptor osikasculptor is offline
osikasculptor is on a distinguished road
Hey Andy,
Why the Bier sound card? Did the other one stop working?
tao
