Old 10-22-2015, 11:18 AM
Digger_Bear Digger_Bear is offline
Digger_Bear is on a distinguished road
Default Re: Metal Excavator - Magom HRC MG1.4
Originally Posted by cdm View Post
I've read very mixed things about their new line of hydros (the old one I wont comment on, we all know the deal). Can you let us know what happens after say 100 hours of runtime?
I try my best to, 100 hours run time could be a long time waiting but will share any thing which crops up.
Old 10-22-2015, 05:09 PM
RCTech9's Avatar
RCTech9 RCTech9 is offline
Looks like a great machine you have built.
RIP FGD 12-19-11
Old 10-28-2015, 04:23 PM
Rimrock Rimrock is offline
Let's make it 5 hours..
Old 11-01-2015, 02:35 PM
Well he's an update.
Split pipe as it comes off the pump. Thing is I didn't have pump running that high and I was indoors showing it off so wasn't putting it under any real strain.
Will have a clean up another evening see if anything looks wrong. For now I'm thinking some clear laquer coat overspray might of weakended the pipe as it's gone at that place.
Old 11-03-2015, 02:00 PM
rc_farmer's Avatar
Master Builder
Hey Ian......EXACT same problem.
Giving up is not an option!!!
Rob
Old 11-05-2015, 11:40 AM
Hi Rob,
Seen yours did your pipe balloon up first, think my it just popped open.
Now replaced and running again.
Old 11-07-2015, 05:26 PM
Bit more work this evening
More clear coat on the black as wasn't shiny enough
Got some vinyls made up
When clear coat has dried on the lid I've a few more to add there.
Old 11-08-2015, 03:16 PM
Today I got to play in the garden.
So bit of weeding O
Ran good, struggled pulling the grass/weeds out which I would expect. Gone through 2 x 2200mah 3S batteries running pump at 20-40% stalling the pistons with the load and no oil leaks pump and pipes only slightly warm so happy running okay so far.
Until!
Thought the grass had locked the tracks and caused a link to snap but looks like a simple derailment although too much tension in the spring to pop back on so looks like I need to open up the track to get back on :BH
But all learning curve. Don't over tax tracks when crambed full of grass!
Old 11-08-2015, 03:21 PM
Also this evening been playing with the settings on the radio.
So now I flick a switch it starts the pump at about 10%. Then
Main boom arm when called for adds 20%
Boom to bucket adds 10%
Bucket adds 10%
So overall the pump is running between 10% throttle at idle to a max 50% throttle with all 3 pistons been used.
It works good but way too fast for me who was running it down at about 20-30% so will make another profile with less power so I can get use to it then switch back to this version when I need the power.
Old 11-10-2015, 06:37 PM
Final few decals on
Almost finished
Last bit, mirrors
And finished pictures
And drivers view
Old 11-10-2015, 06:38 PM
few videos
http://youtu.be/padrM83aOds
http://youtu.be/lIrf4h944ng
Old 11-10-2015, 07:45 PM
chris deacon's Avatar
chris deacon chris deacon is offline
chris deacon is on a distinguished road
Just got a email back from Magom as i could not see the glass for the cab on there site but apparently they do it but they have not put it on there yet.
Old 11-15-2015, 12:43 PM
Well be playing today, all running good. With the new settings to the pump running on demand getting much longer run time no issues with heat.
Also added a setting on the radio where flicking a switch on it automatically adds 20% throttle to the pump, bit like a boost option.
Old 11-15-2015, 03:19 PM
Great job on the paint and details!
Old 11-15-2015, 07:54 PM
Northern Farmer's Avatar
Great job on building the excavator it looks awesome You must be proud!
Old 11-16-2015, 06:23 AM
Thanks for the nice comments guys.
Yes I’m very happy with how it’s turned out, and now using it more to dig stuff I’m slowly getting using to controlling an excavator and having a lot of fun.
Will post more videos when I do them.
Old 03-07-2016, 09:11 PM
headers headers is offline
Where did you get your new slip ring?
Old 08-23-2016, 06:40 PM
docfcybo docfcybo is offline
docfcybo is on a distinguished road
Hello! Great work on your 330D!
I've just bought one from Magom, but need your help about LEDs: what type and power LED have you used? They are very compact, yet pretty shiny!
Greetings from Italy
Fabio
Old 10-25-2016, 11:37 AM
Hi all, not posted on the forum for ages.
Can’t remember. It was from one of the China stores.
Fabio
Again I can’t remember. Something like SMD 2.4x2.4mm white.
I got to admit I haven’t had much time to use the excavator over the year (been busy with other projects) but will point out issues I have had.
Not long after completed it the piston for the bucket stopped working, it had blown a seal/gasket. Magom sent replacements and the piston was easy to take apart and repair all in under half an hour. Not certain if the failure was manufacturing issue of my lack of skills as a new operator, running too high pressure digging into very hard ground. It happened, but hasn’t since so I’m not too worried and was a quick repair once I got replacement parts.
The tracks aren’t that great driving over rough terrain, don’t grip in dirt and spinning on spot tends to derail a track. Again this might be me, digging in sticky dirt (most the videos I’ve seen RC excavators are on sand or dry dirt)
The weight of the model seems light as the model tends to move rather than bucket through the dirt (my sticky dirt again). With sand this isn’t a problem.
Overall still happy with it and glad I bought it. Just shame I haven’t had enough time to use it over the summer.
