Old 11-05-2015, 02:35 PM
cosworth34677's Avatar
Default Re: Magom Brushless Pump
Thanks for all the info. I was going to buy that pump for my excavator. But was wondering what I was like.
Old 11-05-2015, 06:27 PM
Rimrock Rimrock is offline
Well...let's be happy none got hurt by exploding tanks. Version 1.2, come along.
Old 11-05-2015, 09:26 PM
That same pump comes with there new track loader right? Just asking because I was considering it, and this will be my first time messing with hydraulics and concerned about running into te same issues.
Not trolling anymore...
Old 11-05-2015, 09:38 PM
I don't think that pump comes with the track loader. I doubt it would even fit.
Old 11-06-2015, 04:20 AM
Loader comes with the smaller pump (as shown in the webshop), a copy of the original german Leimbach setup.
As with tools, hydraulics and many sorts of mechanical equipment..quality costs...'If you don't got a rich daddy..: get one.. Or save some more months and buy stuff that works out of the box.
The loader looks nice, and runs quick on the videoes I've seen. Just use it as long as the hydraulics last, then upgrade to better components as the original stuff starts leaking/break. That pump setup looks like the same as many in my area use for their Tamiya/Carson semi dumpers, converted from mechanical to hydraulic. Seams to be working alright and looks pretty leakage free.
Old 11-07-2015, 04:25 AM
Digger_Bear Digger_Bear is offline
Digger_Bear is on a distinguished road
Hi Rob,
I had another thought about the pump setup. I'm thinking about setting my system up so the pump only operates at same time as the valve servo therefore the pump won't run when no demand and should hopefully stop excessive pressure in that pipe between the pump and valve block.
I'm still trying to figure out how to program my radio to achieve this and yet to try so will let you know how it effects performance with any delay etc.
Ian.
Old 11-07-2015, 05:52 AM
bigford's Avatar
bigford bigford is offline
rimrock is dead on the money, quality parts the first time
china kat was cheaper then the 4wd. BUT now i'm buying all
new hydros so in the end it will cost me the same... this pump is next on my list of replacement parts
Old 11-08-2015, 03:18 AM
astecme astecme is offline
astecme is on a distinguished road
Sorry link doesn't work, goto premacon, service, page 2 , first thing, it's in German but secamatic is viewable and legend is in English.
link needs .html on the end. http://www.premacon.com/index.php/en...-premacon.html
Old 11-08-2015, 03:31 AM
Originally Posted by Digger_Bear View Post
Hi Rob,
Ian.
You are on the right mind-set there regarding pump set-up. At a fair in Germany recently my curios friend discusses pump set-up both with Fumotec, Premacon and Wedico. They all recommended to mix the pump speed regulator with the valve servos. One should however not let the pump stop totally when none of the valves was operated, but just let the pump speed down to a minimum, idle at like 5-10% of full speed. (There can be a main on/off switch on the radio for stopping the pump when resting for several minutes naturally) If fully stopping the pump one would get delays, higher power consummation, higher risk of air in the system. Further on one adjusted the pump speed to e.g 40% when 1 valve got engaged, and e.g 70% when 2 valve engaged simultaneous, and then like 100% in case of 3 valves operating. The point of the mixing was to have all cylinders moving with similar speed regardless of 1 or 3 cylinders operating. In the model world we naturally used fixed volume pumps, while in the real machines nowadays the pumps are variable volume, and one can operate several valves and more or less keep the same speed of the cylinders.
Old 11-08-2015, 06:30 AM
That is good to know. I did overlook the idle speed so thanks for reminding me.
Now does anyone know how to program that into a turnigy 9xr pro? I've tried adding mix to pump channel but it seems proportional to the servo where off centre adds to the pump speed but other way it subtracts.
Old 11-09-2015, 07:12 PM
You got to get your "+" & "-" 100% in the right order. If both are +, then one of them needs to be -.
Old 11-11-2015, 09:41 PM
rc_farmer's Avatar
Master Builder
Hi Rob,
Ian.
I am using a 10g from Airtronics. I have the pump mixed with the valves so it only runs when demand is there.
I also turned the pump down to about 10-15%. I didn't know all this before you guys chimed in. Really appreciate the help.
Giving up is not an option!!!
Rob
Old 11-23-2015, 05:16 AM
bigford's Avatar
glad you got everything sorted! i just ordered this pump last night
now with new pump,valvebody,tank and cylinders lets hope the kat
digs this year
