Sound Systems tech This section is dedicated to the sound systems for our models. Tamiya MFU, Servonaut, etc. |
Hey guys and gals! I was wondering if anybody can help me to get the rcbrmin 3T sound system working? There are two plugs for the receiver and two yellow wires that I'm assuming are for the speaker. There are 3 sets of red and black wires, two sets that are joined to each other and one set that is separate. I'm thinking the two detached go to the +/- of the battery but no clue where the other red/black wires go. Any help would be greatly appreciated. Thanks
I purchased on of those myself just lately and it only came with a single red and black pair for power. Your right about the yellow for the speakers. Can you post a picture for the lead setup as i don't see that system on they're web site?
Rob |
Thanks Steamer. I got two of them in the mail yesterday and they both have 3 sets of red/black leads, I tried hooking everything up except for the two sets of r/b but no sound. I didn't want to hook the other ones up because I didn't want to fry the whole sound unit.
I believe this is the drawing i used when i installed mine
http://www.beadlok.com/product/image...%20Unit-V9.pdf |
Nope sorry it was Andys drawing i used
http://www.rctruckandconstruction.co...8&postcount=58 |
Thanks a lot for all your help, I'll give it a whirl tonight and hope I can get this thing working.
If you have a "smart phone" the Google translate is fantastic. You can either take a photo and it translates or it works in real time. Stuff from China now becomes really easy to read.
It doesn't however make it any easier to understand sometimes. Just trying to help |
That is different
This sound system is exactly like the one RC4WD sells and they are both knock offs of the Servonaut SMX. One set of paired black and red wires can be used as an input for the speed of the engine sound, instead of using input from the receiver the two wires hook to the motor wires and as the motor speeds up and slows down so does the sound. The other set of paired wires is used for a special horn sound that requires a separate board and speaker. The black and red wires that are separate are the power in for the sound unit.
![]() Connect the SMX to the battery via the red (+) and the black (-) cable. The yellow cables have to be soldered to the loudspeaker. Plug ‘FR/ESC’ (blue housing) into matching port of the Servonaut speed controller (‘Sound’ connector). Starter and horn (F1+F2) are controlled via another receiver channel (here: channel 8). Cables F3 and F4 are normally used in conjunction with a multiswitch (e. g. Servonaut MM4). F3 switches the ‘Martinshorn’ (a special sort of alarm siren used in Germany). F4 is used to simulate an auxiliary drive. You can connect F4 directly to the drive motor as well. Functions F1+F2 and F3+F4 can be interchanged (see chapter Switching Functions). The SM+ add on is installed as shown (short cable plugged into SMX, long cable plugged into free receiver channel, here: receiver channel 9).
SMX manual
Thanks for all the input!!! This site is amazing!!! Got it working great and now the Knight Hauler has sound!!!! I really appreciate all the help guys!!
Have anyone compared the sound quality and functions of the China knock off, too the Servonaut SMX?
I have a servonaut SMT and the Chinese version. The only noticeable difference I've found is lower volume. Same speaker used on each but noticed the SMT is much louder.
what about reg's bigger speaker?
i hate to see the lipo needed to power those in a king hauler!!
i have the duel speaker kit and its not to bad. could be a bit louder |
I think you would need a pretty massive trailer to haul them too because if I remember right they are 44lbs a piece.lol
I can't say how loud my HD is with the two small speakers compared to Mario's larger single but you can tell in the videos that his has a deeper tone. Mine are pointed at the ground also so when you are on concrete it is much louder than on soft dirt. If I ever get a sound unit for my small KW it will be interesting to see how that works since the speakers are mounted in the rad shell pointing forward with shutters that open and close. |
Turn it down, I can't hear it
mine is in the sleeper facing into the cab with no windows in the cab
