Trail and errors that's the way we learn I think you r on a roll to success
![]() Like it keep it going. ![]() |
![]() Anyway. I did get a little work done on the cab. ![]() ![]() Last edited by Krewmember; 11-24-2017 at 10:44 PM. |
Looking good!! wish my unit crane was on a truck! maybe next year lol.
The cab is mounted to the frame
![]() It turned out to be easier than I expected, I just had to make a bracket so that the cab mounts right to the stock bumper mount on the knight hauler frame. ![]() ![]() ![]() ![]() ![]() Last edited by Krewmember; 11-24-2017 at 10:45 PM. |
#26
Just a quick update. I'm to the point where I can start designing the mechanical parts of the crane, which is good I guess
![]() Still a lot of body work to do, but after I get the crane working. I need to start getting more pictures when I'm building ![]() ![]() ![]() ![]() ![]() ![]() Shawn Last edited by Krewmember; 11-24-2017 at 08:40 PM. |
#27
Cool!
#28
Looking good mine hasn't moved an inch
#29
Thats an awesome looking crane truck! It looks like body work is coming together fairly quickly.
Any plans yet how you're going to do the crane part? |
#30
Thanks.
Well, it took me awhile to get this project started. The hardest part was probably deciding what I wanted to do for my first build ![]() Quote:
I have a few ideas. For boom I'm going to use brass, which means I have to make up a jig of some sort to keep things square. As for the hoist, lift and drag winches i will use gear motors. But I will have to get my lathe running ![]() |
#31
Hi Krewmember I have been designing bits of my truck the boom hers a picture . It's laser cut steel that I will weld together . Each section is scale 20 feet long I will make it so you can add or remove the centre sections they will bolt together . I'm getting a KH in June then I can start the truck part . Mike
#32
SWEET looking Boom I'm so wanting that..........
#33
That boom is really impressive. The laser cut steel is a great idea.
I will probably still be using brass for the boom, do to the fact that I have no welder. I can't wait to see the rest your project. ![]() BTW what crane do you plan on building? Bucyrus? American? Bantam ![]() Shawn |
#34
Bucyrus ! I saw one in a quarry 4-5 years ago and decided to build one then but had no clue about rc trucks until 3 years ago and a eureka lite went of in my head . I also found the operators manual which has a few drawings and measurements . I'm going to make the rest out of brass cabs etc . Mike
#35
Get one you can use it to help load Regs box on your frame
#36
Wonder if i can load/unload my steel-box girders with that size boom...........just thinking........
#37
I ran across this while looking for extra details to make for my crane hauler, they've got a few other bucyrus erie machines that may help out, each machine goes on to a page with more pics.
http://www.gerhartmachinery.com/equi...ines-cranes-2/ |
#38
I haven't posted here in awhile, this project has been on the shelf since my last post. I pulled it off the shelf and got a little bit of work done on it.
I rough sanded the cab roof and fenders. ![]() ![]() I also added the grill and some small detail to the bumper as see in this photo ![]() ![]() Still need to do the headlights, turn signals, the brass "Transit Crane" nameplate. And those vent things ![]() I also did a little work on the crane's housing. Made the radiator panel which means the crane has a caterpillar engine ![]() I also added some rivets using a paper hole punch. The door now slides as well ![]() ![]() ![]() ![]() ![]() I'm still trying to figure it out how to go about making the cranes frame. my plan was to mill a base out of a block of aluminum, but I no longer have access to a milling machine. So that plan is out ![]() ![]() Shawn |
#39
#40
Thank you, that's pretty much what I had in mind.
I just looked in to what it would cost to make the base out of brass, and it would be a little out of my price range ![]() But I have access to a welder, so I can probably use steel instead. Shawn |
