Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
#121
Yes just fine. Had it down at the Frankfort toy show a month or so ago. Did just fine. Swapped out the swing motor for a slower unit. Designing the boon parts right now.
#122
Wow thought we were going to have to put an APB out you!
#123
Working serious overtime 10's and 12's and some Saturdays
But also working on the boom design. |
#124
Izzy, ive been out of the game a while. And here i come back and this was one of the first projects i check out. And it looks great! Ill be at Indy this year, hope to see ya in person!
#125
What news Izzy on this lovely mobile crane? Happy NY to all. JD.
#126
Hmmm, been hibernating most of fall winter. Have had the tubing and sleeves for the boom. Waiting on cable spools. Hydraulics made me water to hit it with a hammer so I gave it a rest.
It will be at the Lebanon show and of course Indy Lebanon show link http://www.rctruckandconstruction.co...ad.php?t=11044 |
#127
Been a long winter with many distractiond, but with the help of a good couple friends getting the bug to build again.
So if some of this is repetitive - appologies. But this is where I am at. Lift cylinders, another learning curve here. Thought that sir fittings were air tight right? Not so much. Have to replace the fittings, they leak. ![]() Over all shot, not bad. Going to use an idea from a fellow member on the wheel inserts. Stock foam just way too soft and machine way too heavy. Craft foam sheets is where I am headed. ![]() Boom sections -just finished bolting up. Need spools - friends are priceless. Had to have the caps remade since I designed them too small the first time round. ![]() |
#128
Looking good Izzy, hope to see it in any form at Lebanon.
#129
She will be at Lebanon, working boom is the goal.
#130
#131
Very nice!
Kerst |
#132
Oh my gosh what a monster!!!!! Every part is well thought out and perfectly executed I cant wait to see this thing swinging a bridge section into place.
#133
Pretty happy myself. Took a break from it and had parts made, so cleaning up some loose ends.
Izzy |
#134
Great project Izzy this one must take up a whole shelf
#135
Impressive!!! Knowing how big the front sheeves are, gives me some idea of the overall size. Can't wait to see it!
LYNN |
#136
Yes whole shelf and whole bench. Part of the reason why I bought a utility trailer for my rc's. She won't fit in the Envoy.
#137
#138
One AWESOME build Chris! It keeps getting better. Anxious to see it at Lebanon.
-Terry
FabOne NW Ohio |
#139
After mocking up the boom I set her on her feet. Wow, almost had rims string on the bench the tires were so squished. And that's with the stock foams.
So been asking around - see previous posts. So This is what i did Dissassembly, ![]() Donor wheels with hard foam inserts ![]() Slice part of the carcass off ![]() ![]() Wrap 2 side by side in craft foam sheet - test fitted strip in side tire to get correct size. Had tried tires along but did not fill inside space. ![]() And then squish it all inside. Good thing these tires are soft. Then used clamps to clamp together. |
#140
After having had bolts fall out of these rims, I drilled out the 2.5 mm holes and put in 3mm screws, thread the outer shell to keep the stud look.
Thread Tools | |
Display Modes | |
