Old 12-28-2015, 01:21 PM
Default Re: 1/10 Liebherr Excavator R 984 Litronic
Great to see you back it Markus.
Nifty work on the pin lock mechanism.
Old 12-28-2015, 03:03 PM
DADSGARAGE's Avatar
Just went through this thread again and must say this is an amazing build, all the details are astounding!! WOW!! Really like the scale too...looking forward to seeing more pics!! Keep up the top notch workmanship!!!
KP
Old 12-29-2015, 02:41 AM
Markus K. Markus K. is offline
Markus K. is on a distinguished road
Next I had to improve the pipe holder for the bucket cylinder. I desoldered the brass holder and used a piece of steel. Screws also in M1.6, using a 1.3mm Drill (~ 50 thou) in the brass pieces.
Pipeclamps, waterjet cut, then separated and drilled with a drill jig
And the whole assembly
Old 03-16-2016, 08:29 AM
filippog filippog is offline
filippog is on a distinguished road
Hi Markus,
i gave a look to your project and it is very good. I am trying to build a cat 385 CL and i have one question for you. Where did you buy the hydraulic distributors: I am looking for open centers distributors, I am using a Marzocchi pump 0,32 cc/rev.
Thanks a lot.
Filippo
Old 03-18-2016, 04:29 PM
Hello Filippo, i bought the Valve´s in a small shop in Germany. Unfortunately he don´t support an online shop.
Did you already check the Premacon Shop?
Old 03-19-2016, 06:12 AM
Stefan Stefan is offline
Stefan is on a distinguished road
Thumbs up Re: 1/10 Liebherr Excavator R 984 Litronic
Hello Markus,
for some regrettable reason your build has evolved under my radar all the time until now although we are posting in the same forum section. I´ve just read through the complete thread and after having wiped off the drool from the keyboard I can just conclude that I lack the proper words for describing my amazement and awe.
I just wanted to ask you if the waterjet cutting service you used has an online presence (like laser cutting by CutWorks)?
Thanks for letting us share,
Stefan
Old 03-19-2016, 10:30 AM
Hello Stefan,
thank you for your comment.
Those parts are "swissmade" www.waterjet.ch/de. They were just fabricated within a bigger order from another modelbuilder. He did all the communication with this company. But they already have an upload possibility, so I think you can place your Order online.
Markus
Old 03-22-2016, 08:29 AM
Hallo Markus, yes I did check Premacon, they are sellin Jung valves if i am not wrong, but i believe they are not with open centers. the only open centers i found are from Meinhard from Germany and he does not support on line shop and as far as I know the delivery is very long. Thanks for info.
Filippo
Old 03-22-2016, 09:07 AM
Filippo
The Premacon valves are the Meinhardt design made in steel by? ...is it Jung? Why the need to have them made in steel is beyond me.
All of Fumotec's valves come from Meinhardt.
Old 03-22-2016, 03:16 PM
calum_scania's Avatar
calum_scania calum_scania is offline
calum_scania is on a distinguished road
Joe I ordered valves from Premacon and they are the exact same as fumotec supply but made of steel. My reasoning was to add a little extra weight to the machine
Calum
Old 03-23-2016, 07:20 PM
Hi folks,
yes, I´m using Meinhardt Valves (the big Mega Blocks - i´ve to handle about 2 liters per minute). He don´t support an online shop and he makes not as many as he could sell. Because he don´t need to, it´s not his business, it´s his hobby.
Premacon Valves are fabricated by Jung Fluid. But I can´t tell wether those are open or closed center. I simply would ask premacon via mail.
Old 03-24-2016, 04:10 AM
sinkMe sinkMe is offline
sinkMe is on a distinguished road
I have valves from Premacon and Fumotec. They are exactly the same... in steel, with closed center.
omuller, Norway
Old 03-24-2016, 08:16 AM
Hi everybody,
Premacon valves are closed center, i have just received info from them.
Old 03-24-2016, 01:53 PM
Hi everybody,
.. as I mention in the post above
omuller, Norway
Old 03-24-2016, 01:59 PM
by the way, why do you need open center valves? You might run into problems, when using two different motions at once.
And you simply can "simulate" an open center valve by using an additional closed center. You just have to mix it to your working valves in that way, that it opens just in the moment when you don´t use the hydraulic.
Old 03-24-2016, 03:35 PM
Like loadsensing
http://www.fumotec.de/englisch/detai...sing/index.php
omuller, Norway
