View Poll Results: Would you buy this if it went into production?
Yes I would buy a metal version 13 34.21%
Yes, but I would like a cheaper plastic version 18 47.37%
No, there are better options out there 7 18.42%
Voters: 38. You may not vote on this poll
Old 08-03-2016, 05:48 PM
trewq trewq is offline
trewq is on a distinguished road
Default Re: Tamiya bolt on reduction gear
Just a quick update.
So far shifting servo is not an issue. Partly due to fantastic functions on my spectrum radio where I have reduced servo speed on the throttle channel to a very low percentage, so that the throttle does not go to 100% instantly. It takes a slow ramp up.
The result is a scale looking motion of the truck and a reduced motor/esc/battery load on the take off and breaking.
So, to get back to my third gear issue;
- when taking off with no cargo the third gear acts the same way as when the truck is loaded. I'd reckon that the engagement of the dogs for the third gear are not latching fully, and the same are damaged as well.
In this situation (due to my throttle signal conditioning) the load on the ESC'a BEC is not a problem. The voltage is being held stable.
Now, to touch the AWD GRU and the powered front axle;
- plastic front axle has proven the concept of simple add on FWD. it does make a world of change, and it certainly would be a game changer on my 6x4 Scania R620.
- my choice would always be a full metal axle.
- the 3 speed Tamiya gearbox does seem to be the weakest link on the AWD equipped unit. Mostly due to added load of the FWD, but that should not be a problem when all metal parts are used (metal AWD GRU, metal Front Axle, proper telescopic props hafts (not like the **** I've been making for the test purpose).
- the all opened differential truck with AWD does not get stuck easy. Totally feels like a crawler in an way. Really AWSOME fun to drive this thing around, if only it had a radio that could've been set up like my spectrum to limit the throttle and a steering speeds in order to make things look and feel real...
- the Tamiya steering system is even bigger **** with AWD. I am a strong believer that the hydraulic steering is a must(!) and I'll see if I can convince Doggy to add the hydraulic cylinder in the design files. I'll do the rest of R&D fabrication for this.
Old 08-04-2016, 01:35 AM
Just a couple of thoughts: The Tamiya gearbox is pretty much bullit proof if out together correctly. It has a bit of internal slack, but is very durable.
As for the steering, hydraulic steering would be a cool feature, but I think you will be more than happy with moving the servo between the frame rails. I normally use Hitec645MG servos for steering, and they are strong enough.
Old 08-26-2016, 01:52 PM
JBear JBear is offline
JBear is on a distinguished road
Hello
Look's good. I like it especially with disconnectable front bridge and option to leave battery on it's original place.
Shouldn't the gru be right under the top of the chassis line? The trailer will hit gru if you move the kingpin to correct position (about 10 mm backward from the middle axle, like for example Scania r620 has in real world).
Regards
Jukka
Old 08-26-2016, 02:34 PM
Cooper's Avatar
Cooper Cooper is offline
Just found this thread,, very interesting and inspiring. Printing technology is going to be more and more frequent and being used for more critical parts, in some cases the only way to make a part is to print it as no milling machines can get to cut areas, they are usually printed in metals then heat fused together. Pretty sick technology that some very intelligent folks have solved. I wonder how much cost would be to have them outsourced and printed in metal? But if proving to hold up in plastic then great, metals fail also. Those types of printer are still too expensive for the normal "hobbyist ".
Keep at it! You are definately putting a lot of time and effort into this hobby, I may not be into the trucks as much as equipment but I appreciate your dedication to this any advancement is awesome!! But I think you may have inflated rcp's head a bit with putting that logo in the part!! Lol!! Naaaa, man , keep up the good work!!!
Old 01-09-2017, 05:39 PM
Tommy R's Avatar
Tommy R Tommy R is offline
Have there been more developments on this project? I'm very interested in the GRU along with front drive output! Looking to convert my King Hauler to a 6x6 and this looks to be perfect.
Thanks!
Tommy
Old 01-09-2017, 05:45 PM
Doggy's Avatar
Doggy Doggy is offline
Doggy is on a distinguished road
Saddly no. I moved to another city, started working, and stil didnt setup my new hobby workshop. I hope to set it all up next month and continue the work
Old 01-09-2017, 05:48 PM
Tommy R's Avatar
Sad to know you haven't been able to work on it, but happy the work will continue soon!
Old 05-12-2017, 05:29 PM
TAPII TAPII is offline
TAPII is on a distinguished road
Howdy,
I was wondering if you ever got the AWD GRU finished? It looks like what I need for my truck. Looks great. Keep up the good work. Thanks
Old 05-13-2017, 05:07 AM
Doggy's Avatar
Hi, I did one prototype and gave it to trewq for a few months to test it. He managed to brake something inside, and I still didnt get the time to disassemble it and see what went wrong. I believe something snaped as the truck had fixed drive shaft.
I will do my best to do some work on it soon, as my other projects are near finish now.
Old 07-23-2017, 12:29 AM
Now I wanna buy one of them fancy reduction thingies.
Old 09-16-2017, 06:03 PM
NRS91 NRS91 is offline
NRS91 is on a distinguished road
nice design!
Old 09-17-2017, 04:04 AM
Mikhai Mikhai is offline
Mikhai is on a distinguished road
I want to buy a reducer on the gearbox for a Tamiya truck. I live in Russia. In Russia, bad roads and heavy loads. We need a powerful reducer!
Doggy! Can you send two reducers to Russia?
Old 09-17-2017, 11:59 PM
Originally Posted by TRUCKMAKER View Post
Here is the GRU I use on one truck. Can't beat the price and I've pulled a lot of weight on a pull sled with it. I currently run a stock can for a good all around speed and go to a 55 turn for crawling/heavy hauling.
http://www3.towerhobbies.com/cgi-bin...?&I=LXVLE9&P=7
This is the best photo I have with it mounted.
I like the pricetag on this one!
Old 09-18-2017, 12:01 AM
I wish Photobutt would let us see the pics o fthe d@m thing, & how it's mounted! Do you still have that pic? If so would you consider mailing it to me?
Old 01-12-2021, 08:31 PM
jethro jethro is offline
jethro is on a distinguished road
Are you still making GRU..
Tags
3speed, gearing, reduction, tamiya
