Old 09-18-2016, 08:12 PM
t-meggs t-meggs is offline
t-meggs is on a distinguished road
Question Will a Wedico tri-axle wrecker "crane" fit Tamiya?
Hi guys,
Serious question. I understand that Wedico and Tamiya are not interchangeable, but does anyone have experience with adding a Wedico tri-axle wrecker body to a Tamiya frame or a Tamiya body to a Wedico Triaxle frame?
t-meggs
Old 09-18-2016, 08:56 PM
bigford's Avatar
bigford bigford is offline
Default Re: Will a Wedico tri-axle wrecker "crane" fit Tamiya?
Tamiya is wider than wedico. But it can be done
Old 10-08-2016, 01:50 AM
Kaan's Avatar
Kaan Kaan is offline
Kaan is on a distinguished road
i do have a wedico's 3 axle wrecker truck, if you want i can give you exact size with pictures.
Old 10-09-2016, 08:17 PM
Kaan,
That would be great. I am almost redy tp buy th kit and start as a winter project.
Thanks.
t-mggs
Old 03-20-2017, 12:49 AM
Bluesdocbob Bluesdocbob is offline
Bluesdocbob is on a distinguished road
Yes it can fit you 24-6mm wider than standard I made to fill in pieces from plastic card the other issue is the wheel arches do not line up so either you need to cut the stock sides or re do them in plastic sheet which would allow the addition of more details storage boxes etc....
Bob
Old 03-20-2017, 01:32 AM
just took these shots with detail of where and I use 2.5 m thick sheet and added some 1/4 sq tube from evergreen plastic to strengthen the side and create a good mount point for new sides..
Bob
File Type: jpg Crane Body (1).jpg (157 Bytes, 92 views)
File Type: jpg Crane Body (3).jpg (157 Bytes, 88 views)
File Type: jpg Crane Body (7).jpg (157 Bytes, 88 views)
