#1441
Hi Joe
names for the video We could have escape to next door Canadian digs for victory Fianl break through or Break out Grass is green on the other side so we dug this tunnel Hey Joe i dont know i just know that it will be great to watch. Regards mark Quote:
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#1442
I was thinking moreso a name for the tunnel... I'm still drawing a blank
![]() What I've been working at lately, getting the walkway dug out. I can walk through on the ramp without bending over much, which is handy that the weather is now -20's ![]() ![]() ![]() ![]() The camera doesn't show depth perception very well, it may look rather flat, but it's a 35 degree decline leading into the tunnel entrance. ![]() ![]()
#1443
Great Progress Of your "FunNel' yeah you got my drift ehe
#1444
You're onto something there Bo
#1445
Thanks Joe.
I vas figuring.........it's a fun hobby and you're project is fun and of many thing you do.....you do Funnel.......(verb) a funnel by widening or narrowing at the end. I see no end ![]() Joe's FunNEL Cary on Please i go back to my basement ![]() |
#1446
The Ramp looks really good Joe ... nice cut ..pretty even grade ..Any plans to use the pup or the B4206 with that train you were thinking about ?..Be a good pull for sure ..just not alot of room
#1447
Yes, I need to get busy building stuff...
#1448
Even Drift is a pun at this point. Can't wait too see something making the pull up out of the basement.
#1449
The more I look at this the more impressive it is!! You have moved a lot of material with the lil' Giants!! Looks nice that you can dig that deep and not encounter rock. A few here and there but not solid rocks!! Keep up on the progress pics!!
#1450
Cooper it would be sweet to see your truck down in there hauling loads out what do you think Joe?
#1451
I think the "haul road" might be too narrow for Cooper's 785 & presently it's much too steep, if the drivetrain didn't explode 1st then it'd likely flip over backwards in a couple spots. With a heaping load, the B50's front end lifts the tires a bit as the tandem axles start to crest some hills.
![]() ![]() "Bush fix" - sitting in a dark hole to make a fine wire repair on the quick coupler. The bucket cyl still weeps ever so little occasionally when it's working hard, wires get hard & brittle... is it possible to get 24? gauge petroleum resistant wire? ![]()
#1452
Brought the ol' Stahl adt into service again as I dig out the walkway.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Now to haul this dirt pile into the basement with the B50 ![]() ![]() Great to have an X4 charger again, this is just a couple hrs run time on 3 machines ![]()
#1453
![]() DAYUM!!! it's cold in that tunnel!! Outside is -20's for better than a week. The lean-to is about 5c & the basement bout 12c... I think it could be zero in the tunnel, there's a quarter inch of frost on the cement ceiling. To stay there an hour or longer comfortably I'm wearing a bunny hug with insulated coveralls & winter boots, and I have small space heater blowing warm air directly on my hands as I operate the radio gear. The cold temps have cut the 4s lipo run time close to 10mins, maybe 35-37 minutes.
#1454
might try some 2 inch rigid foam 2 layers on lid use 2by 4 on each side just temp till u get permanent could glue to concrete to lid with pl 400
#1455
Silicone coated is what you want Joe. Good for oil or any greasy spot you can find.
Sized from 12 right up to 30 awg. |
#1456
https://hobbyking.com/en_us/catalog/.../14awg/id/6829
One thing they are good for ![]() Yeah the road might be a lil' narrow for me to ship up the haul truck. But I'm pretty confident the driveshaft will pull up to a 25% grade loaded. She has the power but ideally designed for about 10-15%. But no emergency brakes ![]() ![]() You might be frozen but at least the ground isn't!!! Lol!!
#1457
Servo wire would be bout 24awg, right? Thanx for the tip Rob, and thanx for the link RW, RobotShop has a cdn outlet, looks to be cheaper & in cdn$ too... my HiTec charger came from here with free shipping.
![]() http://www.robotshop.com/ca/en/catal...count&dir=desc Styro board would be a good option for sure Jack, but I won't be there long. Still a couple spots over 35 degree. And the B50 has no brakes either, it'll roll easily at just a few degrees, kind of a nuisance to park anywhere to load that isn't flat and/or soft. The 1st time it happened with pulling 30+ then changing to probably low 20's, I was going maybe half throttle, the front end lifted almost high enough to flip the cab at the edge of a 3 foot cliff. I was right there to catch it, but to juggle radio & heavy model with no brakes ![]() ![]() ![]() Back when this thread started in 2005, I was hauling out of my basement with a Tamiya Mammoth climbing a narrow 16" wooden ramp @17 degrees. Trk half full, loaded front heavy would lift front left tire 1/4 inch, from the bottom all the way to top every time! Moved out 2,5 cu yd that summer... the next summer I put in a conveyer. ![]()
#1458
What did your HiTec charger cost you, and will it also discharge the batteries also what type of battery will it charge Earl |
#1459
![]() http://www.robotshop.com/ca/en/x4-ac...MXeRoCB6vw_wcB
#1460
Currently Active Users Viewing This Thread: 39 (0 members and 39 guests) | |
Thread Tools | |
Display Modes | |
