Sound Systems tech This section is dedicated to the sound systems for our models. Tamiya MFU, Servonaut, etc. |
Hey guys, just one more question!! LOL. I just tried installing the second sound system into my "Pete" daycab but when all connected, ESC will not work. If I unhook the sound system, ESC works fine. Could it be the ESC is not powerful enough to run the sound system? Any help would be much appreciated. Thanks
Thanks for posting guys, helped alot with mine.
The ESC signals are basically 'pass thru' going from RX thru the Sound Board into the ESC. Retrace all of your RX plugs and leads to make sure they're in the right slot. Sometimes it's tricky to get the ESC plugged into the Sound Board. Make sure the separate SB power leads go to a 7.2V or higher battery. (I install an on/off switch in the power lead to shut off sound without unplugging battery) And make sure the top programming plug is in the f1-f2 position. Hope this helps...
WILDCAT T&C Jim B. Colorado Springs |
Hi guys, any one figured hoe to get reversing sound on this module? Thanks
Thread Tools | |
Display Modes | |
