Old 09-14-2017, 12:16 PM
ad2tude ad2tude is offline
ad2tude is on a distinguished road
Default DXE
Anyone using a DxE? Just wondering if this radio would work for my Grand Hauler? Thanks in advance.
Old 09-15-2017, 08:23 PM
Default Re: DXE
Thanks for the help
Old 09-15-2017, 10:54 PM
Default Re: DXE
Spekyrum DX2E?
Old 09-15-2017, 10:56 PM
Backlash Backlash is offline
Backlash is on a distinguished road
Default Re: DXE
Originally Posted by ad2tude View Post
Thanks for the help
Seriously? No reply in a day and a half and you get all hurt?
I'm assuming that you're talking about the Spektrum DXE?? http://www.spektrumrc.com/Products/D...ProdId=SPM1000
I can see no reason why the Specktrum DXE will not be suitable to operate a basic truck...
HOWEVER, I'm not sure if it will be suitable if you plan to use a Tamiya MFC-01/03 multifunction unit, as the MFC-01/03 uses the (analog) trims on the radio to access the extra functions like turning the lights on/off and the DXE appears to have digital trims...
You can use a computerized radio such as the Spektrum DX6 that has digital trims with the MFC-01/03 by programming the dual rate function of the radio to activate the trims..
Old 09-15-2017, 10:59 PM
Default Re: DXE
Originally Posted by skeeter View Post
Spekyrum DX2E?
You need a 3 channel radio to operate a Tamiya Truck.. (Steering, Throttle and gears.) The Third channel will also need to have 3 positions if you want to use all 3 gears..
If I am not mistaken, the Spektrum DX2E is only a 2 channel radio, so it will only operate the steering and throttle (no gears)..
You will need a minimum of a 4 channel radio (with analog trims) to operate a truck with an MFU (MFC-01/03)...
Old 09-16-2017, 08:46 AM
Default Re: DXE
Thanks for the reply's. I have decided to go with a Dx7. Found a great deal on one.
Old 09-16-2017, 02:48 PM
Default Re: DXE
Get the 8, additional 3pos, more mixes, better resale if you were to upgrade or quit.
