Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
truck 11 looking good!!!
I like the gearbox setup. That high lift gearbox?
Thank You.
Yes it is High Lift F 350. |
#26
This build has been on the backburner for over a year........Finally picked up some speed on it again.
This is going to be a 10x8 Beam Hauler XXL. Now the axles fit so next step is to make the rear axle steer properly and smooth. [IMG] ![]() Im also going to build toolboxes. The driveshaft in the pic. is going to be replaced by telescopic ones. |
#27
Brilliant Bo! Following this!
#28
Looks good. That will be one **** of a truck.
Kerst |
#30
Thanks Kerst. Yes i hope it will perform better than the KH. If it does i might give the KH the same treatment.....And there is a KH II in the making too
![]() More of that later ![]() |
#31
Looks Great
#32
Looking good Bo, what frame rails are you using? Why the the different spring mounting on the rear set of tandems? Inquiring minds what to know! Lol
Kent |
#33
Most impressive!
![]() And here I thought a 6X6 would be fine for me. I'm short a few! |
#34
Thanks Pontiacmann
![]() I'm tryin I'm tryin. ![]() |
#35
The frame rails is King Hauler and a slight modification on the suspension in the front. The rear steering axles has a hole pattern narrower than regular straight axles. so the stock wouldn't work. I overcome that hurdle with changing a few parts around......Lesu springs and and brackets from. http://www.ebay.com/itm/stainless-st...72.m2749.l2648 And i use those for couplings to push and pull rods too. Now the fun begin with hooking up the steering.......... |
#36
My KH Beam Hauler got 10x4 and not liking uneven ground much. So i decided this build needed some extra Omf. 10x8. The KH II is all out 10x10 Your 6x6 is going to do just fine. ( All wheel drive is a must this days ![]() |
#37
Here you can see the different width of the axles hole pattern. 2.5 mm x 2 is the diff. in measurement from mid axle to hole centre.
[IMG] ![]() I might put in two set of this one down the road. But for now i'll test this setup. [IMG] ![]() |
#38
The Four Axle Gravel Hauler getting new axles too.
[IMG] ![]() When using one steer axle in the rear normal suspension parts is fine. Just added the heavy duty lesu springs with one more blade in it. [IMG] ![]() Yes all lesu axles going in here too ![]() |
#39
Oh it will! But you know there's always someone with something bigger, brighter & 'longer' so I was just skiddin' with you!
![]() I am learning everyday about rigs so I looked up on You Tube a truck like you're building and found something I didn't know existed. I watched a bunch of Mercedes Benz Actros SLT with dual front steer (axle added) and that I thought is a kit? Or builder modified? Just a learning experience. ![]() 'Anywho', just when I thought I satisfied my 6WD truck need (bought a CROSS freshly built) and avoided having to build something, now I see the need for a second truck! LOL!!! Does this happen often guys? By the way, I didn't want to hi-jack your thread with any pics or videos... just wanted to drop by and say how impressive THIS is and I blame you now that I see my truck collection will grow. ![]() ![]() |
#40
That's Ok Panther.............Brace yourself for impact.........
![]() I started hang on this forum when it opened. And before that the Garden Trucking forum. Took me a while before i felt ready to make any noise. 2013 i've had one truck a Globe Liner. Now a bit later it's a totally different story..........i'm still married though......... ![]() |
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
Thread Tools | |
Display Modes | |
