#121
Thanks for the comlpiments, but ALL the credit is due Stein for open sourcing his build STL (the file type that the 3D printer reads) files! I've taken his ideas, & added my own twist/spin/optional parts etc., to it to make it my own. |
#122
Today, due to weather it was a very short day at work!
![]() ![]() ![]() My axles are now 1/2 an inch wider then the stock axles. I wasn't anticipating this when I started this project. ![]() ![]() I would have liked to got more did today, but I couldn't. When I got home to start on the project, my drill had a dead battery. I plugged it in, before I started the soldering work. By the time I got everything out to solder, & performed the task, the drill had a lil charge to it. It had just enough charge that I could drill the holes in the stock rims, as well as the ones in the bottom of the model for the mounting holes. I know the bolts that hold the assembly to the model are horrendously long & hideous looking. I SHOULD have used between a 27mm to 30mm long m4 bolts, but I've misplaced them. ![]() ![]() ![]() Last edited by skeeter; 10-17-2017 at 11:43 PM. Reason: forgot to add ALL the photo's, & typo's |
#123
I would like to still be out in the garage tinkering, but it's a cold dreary day & the garage is unheated. I'll just have to sit inside, & look at the previous posts on here. Now that my brother got that photobutt thingy installed to fix it so I can see the pics again!
#124
My mentor on this build, Stein did his wheels like this
![]() ![]() I did mine a bit different. This is where the differential in width of the tires comes into play for me. ![]() Had I taken the time to look over his build thread a bit more...............I should have did the epoxy a bit differently. I SHOULD have NOT put any in the very center of the wheel hub. I know for next time! |
#125
You could put the hubs on the motor axle the wrong way and just drill a wide hole in the center of the epoxy, wide enough for the axle and hub cylinder to fit in. That would save you half an inch on each side, maybe.
Stein :-) |
#126
The more I stare at it, the more the wider stance is growing on me. I'll run them as is.................for now, & I'll reserve the right to swap them at a later time.
#127
As we all know by now, I struggle with electronics!
![]() The weather's getting colder, far & few are going to be the warm days. That said I decided I'd better throw a coat of paint on some parts. I painted the Front axle assembly of the front loader today. There are some spots that have runs, but those nasty looking spots WON'T be seen. They'll be covered up with parts of the original model. I was lazy, & DIDN'T want to take it all apart to paint it. I placed a ziplok sandwich bag over each tire, then neatly folded it around the inside of the tire. ![]() Last edited by skeeter; 10-22-2017 at 02:50 PM. |
#128
I know the paint WON'T match exactly the original models paint, but it's the closest I could find.
#129
Yes speed control red wires need pulled on all but the one with strongest BEC. Any single bec works, but i'd use big amps if you've got it
The wide stance could be undone with a drillpress or a dremel if you really wanted. I'd see how it looks in mockup before narrowing. Might help keep it from getting stuck, or let it turn with more force.
#130
Frizzen, thanks for your help, yet again.
I'll keep the wider stance, for now. If, at a later date I find I'm not enjoying it, I reserve the right to narrow it. |
#131
I arrive home from work today, & find that I have mail!
![]() ![]() ![]() BUT......I boogered it up. While I was trying to drill the air cleaner to accept the charge recepticle, ![]() ![]() Perhaps, in the future, I may 3D print a part that will fit inside of it, & look like an air filter. For the time being, it will look like this for the foreseeable future. One of these days, I'll get around to it. |
#132
Have an extra connector that plugs in? Make an air cleaner to glue to it and plug it in the port - remove to charge the battery.
Big iron is awesome! |
#133
That's what will most likely happen, eventually.
#134
I had some more mail awaiting me when I got home today.
![]() ![]() ![]() https://www.ebay.com/itm/2-pcs-Plast...72.m2749.l2649 I know I WILL have room to fit ALL 3 of them in, & it will give me 7.2 working volts. NOT as much as I was hoping for, but I'll take what I can get to fit, so I can get this thing FINALLY running! I also ordered one of these. https://www.ebay.com/itm/1-pc-1S2P-1...72.m2749.l2649 Afterall 7.4V is better then 7.2 ![]() Here's the pic of the battery holder that 3S battery holder that arrived today, sittin gin the dozer. IF I REMOVED ![]() ![]() |
#135
Maybe a good reason to build a dusty enviroment filter? Or check out some bigger machine filter designs? Maybe a D7 style might look good on the d5
Any chance gutting the battery holder might work? The plastic is all optional, just keep the protection circuit and bus bars, insulation tape over the contacts.
#136
#137
I'll address the air cleaner issue after I have a few less things over the fire. Perhaps it's just been recessed to be better out of the operators line of sight. That's my story (For now) & I'm sticking to it.
#138
IF I buy these, & solder ALL 3 red wires together, to make 1 positive lead, AND do the same to the black wires, to make 1 negative lead, would that battery pack function properly?
![]() ![]() https://www.ebay.com/itm/3-pcs-1S1P-...kAAOSwdGFYq~ec Last edited by skeeter; 10-25-2017 at 01:15 AM. |
#139
I don't know much about the 18650 cells, but you can build them into packs that way.
If you solder all reds together, and all blacks together, you will have a 3p pack. It has single cell voltage, 3x the amps. If you solder a red to black, and another red to black, you'll have a 3s pack. It has 3x cell voltage, and single cell amps.
#140
Thread Tools | |
Display Modes | |
