Old 01-09-2011, 11:10 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: RCLogger
You used a scroll saw to cut that tooth out Greg?
And it looks like your tip is replaceable too?
Joe I used the band saw to cut it out, just takes a little more time and patience than I have. The tip is replaceable, I milled out the back and used the split pins to hold it in place.
Old 01-09-2011, 11:24 PM
RCLogger's Avatar
Thanks for the kind words guys !
I guess you could say its a little brother, but Dan it is from another family compared to your machine. Mine is stand a few hundred feet away scale compared to yours.LOL
Nathan I use photo's from the internet and I scale up brochers. As far as the track tension, I do use a spring in the track frames to keep the tension, also if a rock or any type of debree goes into the idelers the spring compensates. If you look at the 1-1 the pivot point is just ahead of the sprocket on the track frame. They have a system to keep the proper track tension as well...
Old 01-10-2011, 11:36 AM
Vanisle Vanisle is offline
Wow, you work quick. It looks great. What will you do with your other dozer?
Old 01-10-2011, 07:55 PM
Oil Field Construction's Avatar
Oil Field Construction Oil Field Construction is offline
Oil Field Construction is on a distinguished road
Great progress Greg! Love that you made the tooth on the ripper removable, then when it wears down from ripping rock you can change it out
Old 01-11-2011, 02:10 PM
RCLogger's Avatar
A little more work done on the ripper. Still have some more work to get it finished up.
Old 01-11-2011, 08:54 PM
Heavy Metal Heavy Metal is offline
Heavy Metal is on a distinguished road
Originally Posted by RCLogger View Post
I am planning on using a Liembach pump Joe. I am starting to search around for one, would be nice to get a half dozen of them..
You're not kidding. Make it an even dozen.
I think you mentioned using air cylinders from McMaster for this and other projects...they hold up pretty good? I think I like the looks of those better than Clippards. Keep thinking I need to do something to turn down the square ends on the Clippards.
Old 01-12-2011, 05:03 AM
Why don't you order direct from TTM Modellbau? Order in bulk, bank wire, you'll have your stuff inside of two weeks.
Old 01-12-2011, 12:41 PM
Stuff's Avatar
Stuff Stuff is offline
love the chain drive. looks very useful!
my YouTube is -
Subscribe!!
My Facebook -
Old 01-12-2011, 01:11 PM
td9clyde td9clyde is offline
Dozer Builder
awsome work i am likin the 8 looks great keep the pics rollin
Old 01-12-2011, 02:14 PM
fantastic build so far... starting to like these scratch built dozers a lot more... "potters off to ebay to look for a milling machine!"
Elliot.
Old 01-14-2011, 11:59 PM
RCLogger's Avatar
The Ripper is almost a done deal. Ready to start the next section.
IMG]http://i124.photobucket.com/albums/p17/logger_02/finishedripper002.jpg[/IMG]
Old 01-15-2011, 12:03 AM
RCLogger's Avatar
Old 01-15-2011, 12:05 AM
RCLogger's Avatar
Old 01-15-2011, 12:08 AM
RCLogger's Avatar
Joe you can get Clippard without the square ends as well. I have used Clippard for the blade lift cylinders on the D8 build.
greg
Old 01-15-2011, 01:23 AM
tracksntreadslou's Avatar
Looks good greg ...I may have to come have a look at that bad boy in person this weekend.
Old 01-15-2011, 12:36 PM
Iron Art's Avatar
Iron Art Iron Art is offline
Iron Art is on a distinguished road
Greg, The Cat is looking like a piece of "Aluminum Art", How many hours a week are you able to work on this project? Looks like you are ripping rite along. Fred
Old 01-16-2011, 11:55 AM
Greg! That Unit is looking Serious!! Ripper makes that Unit!! And looks like it has lot's of depth for ripping.
Old 01-16-2011, 03:36 PM
JAMMER JAMMER is offline
Thumbs up Re: RCLogger
Greg you are doing a very nice job on that dozer looks great keep it up. I like your single tooth ripper better than the multi tooth. Ed
Old 01-23-2011, 12:41 AM
RCLogger's Avatar
I had a chance to mount some pads on the chain today
Old 01-23-2011, 01:20 AM
steamer's Avatar
steamer steamer is offline
Greg Looking better every day. Did you spin that side up. If you put some lead in her, she'll have some serious push for the blade and pull for the ripper
Rob
