#161
Nice looking apparatus!
That should be a ton of fun to start converting! How many functions are you thinking about? (Yay, i'm a bad influence)
#162
Ideally, ladder extend/retract, as well as rotation too, plus working emerg lights with siren & a working water pump too. In reality, IDk what will come of it. It'll be a last project to do, after I get the rest did.
#163
This might be useful.
German build of a USA firetruck that was built in China https://translate.googleusercontent....NtzJ-DkCTqWN0g
#164
Thank-You, sir for the link. ALL information is helpful, as I've never tried doing a corded to true RC conversion.
#165
Being unable to locally source anything larger then 1/2" heat shrink tubing, I had to order the 1.5" heatshrink tubing from evilbay. It was awaiting my arrival when I got home from work today, so I put it to good use. The 600MAH NMH battery pack for the Bruder D5 conversion has been finished. I made 2 of them, as they ONLY last about 8-10 minutes, from the time they are turned on, to the time they are dead. since the battery life is such short lived, I've decided to forego the on board charging system, & the battery will need removed/swapped when it dies.
One of the 2 COMPLETED battery packs. ![]() I smoked 2 batteries while trying to figure this out. I had BOTH + & the - terminals on them bused together. I was wondering why the batteries were getting so warm, & they sparked each time I touched the buss bar. Now I know! |
#166
That sucks, atleast you only smoked 2 batteries. Maybe you can use the 600mah batterys in something with lower current draw.
Cord remote to real RC can be easier than starting with a clean slate. It's going to have some kind of a gearbox and steering axle already installed. Then it's more about pulling old electronics and swap with something good.
#167
The wintertime slowdown with work has started to happen. I didn't work today, so I ran a few errands, then tinkered in the garage a bit.
The Bruder 574 front loader conversion got some love today. Under the hood is bolted the Sabertooth 2X5 that will controll the bucket & arm lift. ![]() Speaking of the lift rams, I did mine a bit differently then my mentor's. I decided that since I added a LOT of weight to the model, it would have more force applied to the rams. That being said I abandoned the method for fastening the rams to the model liek his, & came up with my own version. ![]() Here's the parts I used to do it. ![]() mocked together ![]() The "blind nut", AKA ribbed nut (I've heard them refered to both ways) did require some slight modification to the 3D printed parts that it goes through. I believe I had to drill (CAN'T remember for SURE) a 6mm hole about 1/4 inches deep into the print part. Then I used a M3x40mm bolt to go through both of my custom built aluminum parts, into the blind nut. Between the alum part, & the actuator there is a washer, followed by an M3 nut, then 5 more washers. There is a locknut behind the custom aluminum parts that holds the actuator to it. one more pic, showing the wiring of the 2X5 controller finished. ![]() Tomorrow, I hope to start the wiring for the wheel motors! |
#168
#169
Well, today DIDN'T go quite as planned. I went to Batteries + Bulbs today to try & get batteries. Theirs was worse then mine, as all they could source was 2/3AA 400MAH batteries.
![]() As I got back home, & prepared to start in the garage, the phone rings. It was the call that sold the old ford ranger pickup truck that had been sitting for a few years. I was keeping it as a backup rig, but decided to let er go. ![]() Flushed with cash, & having become such a large contracting services company, we needed a tax write off. We decided it was time to invest in a racecar! ![]() McQueen was purchased from Fred Meyer about 2 months ago. It's the largest "cars" toy that I recall ever seeing made. It works out close to 1/10th scale. When I walked into the LHS, their jaws about hit the floor when I told them I WASN'T there to buy parts, ![]() ![]() ![]() Here's what's left of the stock chassis, & the packaging that it came in. Since McQueen WASN'T made as an RC, I had to gut the chassis from it. Who would have known them little screws they pt in it would be so d@m hard to get out? ![]() ![]() The body gutted from it's childs toy chassis ![]() Here's the mock up on the donor chassis, of the Traxxas Rustler. ![]() I've got smaller tires to place on it yet, as well as figure out how/where to secure the body to the chassis. McQueen will fit right in with his buddy Towmater sitting next to him on the shelf. Last edited by skeeter; 11-10-2017 at 07:31 PM. |
#170
I also took the D5 out for a lil video session today. Sorry, it's a small video snippet, as that's ALL my phone (ONLY thing I got that'll take video's) ONLY takes short vids before running out of memory. I need to adjust the blade servo a bit, so we have some down pressure to the blade. With the blade improperly adjusted, I WASN'T able to get down far enough to push well due to the rocky terrain.
#171
![]() I'm already feeling overwhelmed looking at it. I may have bit off more then I can chew with this project. ![]() The other functions, lights, sound, fwd, rev, ladder extend/retract, ladder movement side to side, I'll have to take a look at it later this winter. As IF I DIDN'T already have enough projects, I felt the need for another. ESPECIALLY with the insiders information I just hears about. Something bad is about to happen near the new year with the tractor industry, & the farmers won't be able to get enough machines to do their work this year. Having the inside scoop, I had to get in on the action by getting some equipment while they can be got. I hope that little twerp at the tractor manufacturing plant ISN'T pumping me full of BS about the grave situation that'll be happening. So.........................................knowing the secret insiders info, we acquired this little gem, a NewBright tractor https://www.ebay.com/itm/New-Bright-...72.m2749.l2649 Also had to acquire the wagon to go with it https://www.ebay.com/itm/Vintage-New...72.m2749.l2649 Hopefully we'll have enough time to get em right so that they are ready to go to work when they are needed. Last edited by skeeter; 11-11-2017 at 09:45 PM. Reason: typo's |
#172
Today, after doing a few things I needed to do, I started the Weyerhauser Logging truck conversion. I didn't get too far along on it, but it's a start. I got as far as chopping off the sleeper, adjusting the width of the previously rear panel/access door on the sleeper, & marking out where I intend to place the rear window.
![]() The hardware was previously used for open/close the access panel.......it's only there temporary, until I get everything sorted. Once things are ready to be glued in place, I'll remove them, & patch their holes. ![]() I took 5CM out of the center(ish) to make the panel fit it's new home. ![]() |
#173
1 more photo from today. This is what the sleep portion looked like, after i hacked it off. I used what Bo, in his steering mod tutorial calls a "FAST TOOL" to make the cut. I stayed rather far away from the cab portion of the truck while doing this. I would rather have a NON needed part look ragged & haggard, then the cab of the truck.
#174
Instead of 2/3AA cells, Have you tried looking for 2/3A cells, they're usually good for 1500-1600 mah. They're about 0.650" diameter by 1.150" long.
Nice Rustler, or is that a Rusteeze now? I've got an old randomly upgraded ancient MSC version of it, you'll have fun. Don't get overwhelmed, use the Elephant Method. With the Ladder start with the basics: steer, drive, flashy lights, maybe some noise. Then later on when that's not enough, get a couple cheap esc to run the ladder up/down, right/left, in/out. If after all that, you STILL have some insanity and the room to do it, maybe look into nitro fueltanks, fuel tube and fountain pumps or windshield washer sprayers. Water cool, but its a gimmic you can't do all the time and can easily trash your electronics. Make conversions run and drive as soon as possible because it gives momentum to keep you from getting burned out because you already see the light at the end of tunnel. I didn't know they did cable control tractors, that's pretty cool. I wonder how well it will be able to pull? Nice progress on the daycab.
#175
Great website I found to make your fire truck put out some flames. https://www.harbormodels.com/firemonitors.html
#176
Thank-you for the link. That's so cool, that they have WORKING version of them. I wonder if the 1;16th scale version is adaptable to working order?
#177
![]() https://www.ebay.com/itm/12-Pcs-2-3-...cAAOxy2YtRtToU The Rustler, it's now morphed into a Rusteeze race car. I like it a LOT! ![]() I do concur. Vehicle driveability will be the first issue tackled, when I get around to this project. I didn't know they did cable tractors either. I was searching fleabay for "NewBright" & thats how I found it. I looked through several pages of garbage ![]() Hopefully it'll do alright pulling. I may have to add some weight over the drive tires to make it function more gooder. ![]() The daycab.............well, it's just a start. I've got a LONG way to go before I cross the finish line with that project. ![]() Last edited by skeeter; 11-12-2017 at 11:30 AM. |
#178
The 1/15 says display only. I'm sure you could find some some wear that would work.
#179
Come to think of it, it's got one on it already, I wonder if I could just hook hose(es) to it & make it work? I'll have to check next time I'm out in the garage.
#180
I'm surprised none of the RC logging people here have done this Letourneau log loader yet. IF I had access to, or room in the garage to have machinery, I'd be doing one of these. I'm sure it'd be a one off, that no one else would do.
![]() Last edited by skeeter; 11-12-2017 at 08:10 PM. Reason: Letourneau spelled wrong |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
Thread Tools | |
Display Modes | |
