#241
Looking good with the skidsteer.. just mite be the next piece I'll be looking to buy.
#242
Thanks for the encouragement, Lenny
Yesterday, when I arrived home from work, I had a package I've been awaiting fir a LONG long time! The SLOW boat carrying it FINALLY made it's way to me from China. ![]() ![]() ![]() Today I didn't work, due to a Dental appointment. ![]() ![]() ![]() I'm excited to cut the cord off this little rice burning hot rod, but have other projects ahead of it. Once I get a few more parts, the dump truck will be taking over as the HIGHEST priority build. After all, I'll need something to haul away all that dirt that the new hoe will be digging up! ![]() |
#243
Atleast you've got some battery options to work with. It looked like you might have been able to run 4 of the 2/3A across the back counterweight, then stick the other 2 onto that going into engine compartment?
Wait, the 2/3A are 1600, but the 2/3AA are 1800? Do the AA have a slower discharge rating? Nice scooby, mine should just be couple days out then.
#244
Unfortunately, neither evilbay seller was able to provide a "C" rating for the batteries, so I'm unsure.
Yes sir, your new ride SHOULDN'T be too far away. Yeppers, I have a several options for batteries to work with. I COULD have ran the 2/3A battery pack, but then I wouldn't have room to put in the Sabertooth 2X5, or the receiver. With the smaller 2/3AA pack, I can have the Sabertooth in the back with the pack, as well as shoe horn the receiver in there too. The 4CH receiver for the Spektrum is slightly too bulky to fit under the seat area. Last edited by skeeter; 12-08-2017 at 09:05 AM. |
#245
Tonight, after work, I tinkered with the Bruder Skidsteer conversion some more. I got as far as installing 7 testing the driveability functions. I added another 2/3AA battery to the pack. It now runs off from a 2/3AA 8.4V 1800MAH battery pack. I also got the on/off/charge switch installed. IDK, yet where I will shoehorn the charge port at on this thang. Perhaps, at/near the rear of the ROPS, on top perhaps?
![]() Even with the lighter weight batteries that make up the pack, the thing is still slightly heavy to the rear, just like the 1:1 is. I still think I'll do the skeeter special, just a bit to it, as it's not quite right.....yet. ![]() Once it FINALLY gets did loading, I'll have a short video of the driveability testing to post. |
#246
as promised, here's a short clip testing the drive functions of the skidsteer
https://youtu.be/nD5vWxLdMEw |
#247
Nice to see it's fighting a little less and moving under it's own power now.
Did you put any brass tube bracing in the lifting arms yet?
#248
Yes sir, It feels AMAZING that it's FINALLY showing progress. The cousin Delta Loader, hasn't made any progress.
Brass tubing in lifting arms....no sir. The arms on it are I think built very solidly. On it's cousin, I WILL be placing some reinforcements in it's arms. The wheeled version has a solid boom, unlike tracked version. |
#249
My bad, i hadn't actually seen the wheeled bobcat in person yet.
A while back you were asking about figures, i just ran across these being used in a M35 in 1/16 build over on scale4x4. They'll be a little short, but seem to have great detail http://americandiorama.com/index.php...tegory&path=69
#250
Thank-You sir for that link! I've found a few things I might could use for future projects there.
#251
This morning I was sitting in the garage tinkering with the Bruder Skidsteer conversion.....well trying to, but this guy WOULDN'T stay off my lap.
![]() I think he was enjoying the warmth that Mr Heater Head was providing. All was quiet when I heard the truck pull into the driveway. When the delivery gal got out, I noticed she was carrying a rather large box. Normally, I'd just sit back, & let them take it to the front door. This time, knowing I was anxiously expecting a delivery of about that same shape/size, I hopped up, & went to greet her. I was overly joyed when I found out the package was mine. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#252
Now the work begins! I'll be going through it with a fine tooth comb, to make sure EVERYTHING is properly tightened, & locktite where needed. then I'll have to watch a Youtube video of how to properly fill & bleed the hydraulic system, before I get to doing that.
#253
Hi Skeeter
Nice purchase Enjoy your new machine a good pre inspection is always worthwhile and usually pays off in the long run. Looking forwards to seeing it in action.
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#254
Got some time out in the garage today, & finished the Bruder Caterpillar D4 conversion.
![]() I know the bolts that hold the blade wear plate to the machine are a bit too large, & there are too few of them. They are what I was able to source locally. ![]() Got a chance to get the 4200Xl out to play today. ![]() ![]() ![]() I must say I was impressed with the digging power of the RC4WD 4200Xl hoe. ![]() ![]() ![]() |
#255
I'm still working on the Bruder skidsteer conversion. I have to figure out where in that thang I can put a BEC unit.
#256
Thanks again for the info on his upgrade parts! |
#257
No work today, so I had time in the garage to mess with the Bruder Skidsteer conversion. I was able to show horn a BEC unit into it. With the 5V BEC unit in it, it now functions, as it SHOULD! I'll post a lil teaser vid of it. Sorry, the nephews were visiting, & got in the video a bit. They are both 2, & thought this was the neatest thing they've seen yet!
https://youtu.be/J4JD0Bu_aw8 Sorry for the crummy video quality. The video was taken using my cell phone. After battling this one, I'm unsure if I'll be attempting the Bruder Delta loader conversion! This one was cramped enough to try & fit everything into. There's even less room in the delta loader to fit it all into! Last edited by skeeter; 12-12-2017 at 11:02 PM. Reason: typo |
#258
My friend JUST sent me a short snippet of the video he took of the RC4WD 4200 excavator he took. This shows the track freewheel problem I'm talking about. When I try to dig, the tracks freewheel, & pull the machine towards the bucket. They SHOULDN'T move, as they are doing. RC4WD is sending replacement parts for it. I'm sure they will get here before the upgrade kit from SoylandIndustries does. I'll R+R the stock motors, so I can use the machine, until the upgrade kit gets here. Once the upgrade kit arrives, I'll switch to those motors.
https://youtu.be/Hwz6pSUzERo |
#259
I did it, I ordered from Magomhrc the metal bucket for the Bruder Liebherr L574 loader conversion. It should arrive me in about a week, or less. As soon as it gets here, & I get it installed, I'll try to post video of the loader
#260
I found a neat interior for the RC4WD on thingiverse. I think I'll print it out, & see if it fits well enough. HOPEFULLY it's a good fit!
Currently Active Users Viewing This Thread: 19 (0 members and 19 guests) | |
Thread Tools | |
Display Modes | |
