#1621
Carp, I have two 4206's, one has 3 valve hyds, the other has none.
Tom, stick time since 2002, indeed all good fun. ![]()
#1622
I saw a bucket, i was just suprised to see an actual seat down there.
Wow, i didn't realize that's been going on since '02
#1623
My seat is "up there", that's the back of my shop.
![]() I got my 1st my hydraulic construction model, Liebherr 922 excavator, from Stahl/Leimbach summer of 2001, finished building it Feb 2002. Basement enlargement project started winter of 04 - 05.
#1624
Been working on a new B50 with a pup this winter. I went with brushed motors in this one, it'll run a little quicker than the old one with brushless.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The old B50 needed some attention a few weeks ago, had to pull the pump out to tighten the belt. ![]()
#1625
Another B50!
#1626
Looks real good Joe nice welds. Ed
#1627
looks awsome Joe. your fleet of trucks will beable to move alot of material.
#1628
Thanks for posting the pics of the new truck. I’m sure this one will live a life of good use . And nice work on the hitch!!
#1629
Wow you built those 1.5 B50's fast!! Does it come painted? Looking forward to this beast hauling dirt.
#1630
just currious if you put all the dumper trucks in a line how many feet long would it be lol
#1631
Fast?! What are you being funny?
![]() ![]() ![]() ![]() Anyways, just about done with this adt & pup ![]() I made a valve divider block from brass for the pup ![]() ![]() ![]() This dump cyl was on the trk, right side... the flexible hose going to the "T" I think I made it a bit too short, box going up/down - changing angles tugging a bit on this fitting broke it loose from the tube. Pipe goes up to top of tube & broke loose from that soldered joint... buffed the paint off, resolder, repaint, put it on pup after dinner today. ![]() ![]() Got the box on the pup, put oil to the cyls ![]() This is where the connection is for the pup hyds ![]() Got a leak, hoping I just over tightened the fitting & crushed the seal too much... put on a new fitting with some thread seal... give a couple hrs to set & try it again. ![]() Made up some exhaust pipes from 5/16 Plastruct tube for this adt & the others ![]() This air cleaner is 3D printed, used an 8mm magnet to hold it place for pictures & filming, leave it off during regular use so it don't get so dirty. ![]() ![]() And I'm motivated to get busy putting this WA500 wheel loader together next, it's only 4yrs next month that I've had it ![]() ![]() ![]() ![]() Degrease the cyls today & paint them yellow ![]() The drive belt on my lathe is toast ![]() ![]() I was looking on https://www.mcmaster.com/#drive-belts/=1booul2 (I see the link won't go directly to page I was looking at; it's the T5 series timing belt) My operators manual gave the dimensions 124 x 1.5 x 15 which is metric for teeth - depth - width When I measure the length I get 584mm & pitch is 5mm Gonna be one of these 3 belts ![]() ![]() T5-575-16 575 115 5 Urethane Gray -13° to 176° 1679K518 9.10 T5-610-16 610 122 5 Urethane Gray -13° to 176° 1679K545 9.51 T5-630-16 630 126 5 Urethane Gray -13° to 176° 1679K522 9.51
#1632
Got er done... well except for the decals & a couple of other bitty parts that'll show up in a few months.
![]() ![]() ![]() ![]() ![]() Missing the fuel cap & fuel drain plug ![]() ![]() ![]() ![]() Off to get the 1st load ![]() Start painting the cab on the old B50 shortly... more than 50cy hauled in the last 3yrs ![]() ![]() ![]() ![]() ![]() Trying to pull the steep grade with pup in tow, the rims on the tandem axle were slipping bad in the tires, I had to pull hard by hand to get the truck up the hill... I really hate gluing tires... not sure what this gasket maker goo will do, smeared it on today, see what it's like tomorrow. ![]() ![]() ![]() ![]() Broomed off the ramp, nearly 5 gallon of clay powder/dust, very slippery. Road is wearing down bad! ![]() ![]() Soaked the roadway with water, sprinkle on the fines, soaked it some more, rebuild the surface to make it smooth. Lay down some asphalt to protect the surface. ![]() ![]() The fines pile grew a lot in the last week! ![]()
#1633
Now that is a lot of goodness, and hard work done. Really enjoy watching the progress a lot, and with new machines on the plant new challenges shows up. Heavy traffic can put some roads on a test for sure. hope you can adjust for a smooth haul road and get it where it needs to go. I could not resist to mess with one of your pictures.........a drone pix of your site....looks like so 1/1
Hope you don't mind i did this.......[IMG] ![]() Looking forward to vids....crunch crunch. |
#1634
Really nice work on the new truck Joe. I was curious how the dumping would work with the pup but now I see.
#1635
Thanks for the photo's Joe
You are getting some building done this winter... I would guess you powered up the trailer as well ? greg |
#1636
Did you just zoom the pic Bo? It does look moreso 1:1
![]() Thanx Tom. The dump area is almost too small for this combo. I do have a 2x25 Sabertooth in the trk & a power wire coming from the cab Greg to put power to the axles on the pup, don't really want to b/c cornering makes it act weird... I have some hubs with one-way roller clutches that I made up for the 8wd 4206 cross dump, but took them off b/c I discovered I sometimes needed 8wd in both directions with that rig. I can't make that alteration till I get my lathe working again... ordered belts from McMaster yesterday... the slow bus through customs. ![]()
#1637
Hey Joe.
I turned the pic. counterclockwise a bit to most of the revealing wall was gone, and cut out the footprints from the Giant..........lol Would love a similar pic. with your New awesome haul truck in there also......keep snapping picture plz. |
#1638
Came out great Joe looks awesome
#1639
Thanx Brandon, I like it too... get this rim slippage problem solved, then hammer down!
A vid showing the 963 leveling the fines pile, had to reload the vid b/c the original kept pausing for reasons I do not know ![]() https://www.youtube.com/watch?v=q_xf_I581ug
#1640
Crunch Crunch. The reload works good, So does the dozer.......and i said it before.....Excavator Operator Extraordinaire...... Now i gotta say Dozer Operator Extraordinaire.......Very nice work !
Currently Active Users Viewing This Thread: 26 (0 members and 26 guests) | |
Thread Tools | |
Display Modes | |
