scotty k: I heated the pinion with a heat gun and put the motor in the fridge. I slipped the hot pinion on the cold shaft and got an interference fit. I need to contact Lesu and get the specs of the pinion.
Lil Giant: the metal parts are aluminum, unfortunately no bushing at the pivot point. I find it weird that they did this considering they used flanged bearings for the axle pivot !! once the pivots wear out I will drill them out and put in flanged bearings. |
Here is a video I did about the hydraulic valve block: https://youtu.be/aNGVRHwqO8E
here is a video about some of the general progress on the build: https://youtu.be/eLRdwY-y-aI
servo adapter:[url=https://postimg.org/image/t48npguth/]
![]() servo adapter installed: [url=https://postimg.org/image/ct8jt4811/] ![]() The stock servo horns had to be trimmed down to fit inside the adapters, nothing a dremel cant handle. Last edited by Table Top Trucker; 03-13-2018 at 11:55 AM. |
#27
The kit came with 5 Tower Pro servos, I wasn't feelin' it. I decided to run Spektrum servos, part # h3050. these servos are sub-micro heli servos.
#28
Hi
Nice build log thanks for sharing. I too would swap out the tower pro for another servo they are not bad just would not use them in a valve block so now what you mean by saying not feeling it ![]()
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#29
If you would please tell me the tire dimensions? Thanks (:
#30
Cat966c; sorry it took so long to get back to you. Tire diameter is about 4.2 inch O.D.
wheels are about 1 and 19/32 of an inch wide, dia. is approx. 2.5 inch. hope that helps. |
#31
Hey, awesome!! No problem man. It usually takes longer to get a response on here (no offense) so you’re good! Thanks!
#32
Hey Cat996, don't quote me but I think the wheels/tires can be ordered through Lesu. I know for a fact that the loader axles and a pass-through version of the loader axles are avail. for purchase. The fact that they have a pass-through version makes me think they have an ADT in the works.
#33
here are a couple more pics of the build:
![]() this first shot is looking into the back of the front half of the frame, it shows the second hydraulic manifold. The plumbing is almost complete !! Bucket lift arms bolted up: ![]() Another shot of the front half: ![]() Last edited by Table Top Trucker; 03-27-2018 at 11:45 PM. |
#34
#35
look for at least one new video in the next 5-7 days. Thanks for following.
#36
Just posted the lastest video a couple hours ago; https://youtu.be/nC7stYh4Bds
#37
#38
#39
Almost 24" in length: url=https://postimg.org/image/r5o31bg9z/]
#40
Tags |
kit, lesu, liebherr, loader, wheel loader |
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
