Old 03-01-2018, 11:51 PM
Default Re: Lesu Liebherr 574 loader kit build
Originally Posted by Table Top Trucker View Post
Here is a shot of the motor with the mounting plate bolted up: https://postimg.org/image/q8kgagrad/][/url]
Although the drive motor has a D-shaped pinion shaft the pinion doesn't have same D-shape. The pinion is a press fit more or less and does not have a set screw.
On the plus side the transmission had plenty of grease in it and operated smoothly.
Here is a pic of the motor\transmission assembly: https://postimg.org/image/3wmnh1plh/][/url]
I'll be anxiously awaiting to see how well you like this setup! I've got the same thing in a Tamiya frame waiting for me to finish building it. I wonder if it'll be strong enough to hold up to the weight of a superdump?
Old 03-07-2018, 12:11 PM
Table Top Trucker Table Top Trucker is offline
Table Top Trucker is on a distinguished road
scotty k: I heated the pinion with a heat gun and put the motor in the fridge. I slipped the hot pinion on the cold shaft and got an interference fit. I need to contact Lesu and get the specs of the pinion.
Lil Giant: the metal parts are aluminum, unfortunately no bushing at the pivot point. I find it weird that they did this considering they used flanged bearings for the axle pivot !!
once the pivots wear out I will drill them out and put in flanged bearings.
Old 03-07-2018, 12:13 PM
Here is a video I did about the hydraulic valve block: https://youtu.be/aNGVRHwqO8E
Old 03-07-2018, 12:15 PM
here is a video about some of the general progress on the build: https://youtu.be/eLRdwY-y-aI
Old 03-13-2018, 11:47 AM
here a couple shots of the hydraulic valve assembly.
url=https://postimg.org/image/e8a4hsr3p/][/url]
Old 03-13-2018, 11:48 AM
servo adapter:[url=https://postimg.org/image/t48npguth/][/url
servo adapter installed: [url=https://postimg.org/image/ct8jt4811/][/url
The stock servo horns had to be trimmed down to fit inside the adapters, nothing a dremel cant handle.
Old 03-13-2018, 11:53 AM
The kit came with 5 Tower Pro servos, I wasn't feelin' it. I decided to run Spektrum servos, part # h3050. these servos are sub-micro heli servos.
Old 03-17-2018, 05:07 AM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi
Nice build log thanks for sharing.
I too would swap out the tower pro for another servo they are not bad just would not use them in a valve block so now what you mean by saying not feeling it
Regards
Mark
Over the Pond in the UK
Member of Ribble Valley Radio Controlled Truck Club
my weather station
Old 03-22-2018, 11:54 AM
Cat966c Cat966c is offline
If you would please tell me the tire dimensions? Thanks (:
Old 03-27-2018, 11:17 AM
Cat966c; sorry it took so long to get back to you. Tire diameter is about 4.2 inch O.D.
wheels are about 1 and 19/32 of an inch wide, dia. is approx. 2.5 inch.
hope that helps.
Old 03-27-2018, 06:25 PM
Hey, awesome!! No problem man. It usually takes longer to get a response on here (no offense) so you’re good! Thanks! ��
Old 03-27-2018, 11:31 PM
Hey Cat996, don't quote me but I think the wheels/tires can be ordered through Lesu. I know for a fact that the loader axles and a pass-through version of the loader axles are avail. for purchase. The fact that they have a pass-through version makes me think they have an ADT in the works.
Old 03-27-2018, 11:42 PM
here are a couple more pics of the build:
this first shot is looking into the back of the front half of the frame, it shows the second hydraulic manifold. The plumbing is almost complete !!
Bucket lift arms bolted up:
Another shot of the front half:
Old 03-27-2018, 11:48 PM
Here are a couple shot of the valve-block bolted up: url=https://postimg.org/image/g1ztubb2v/][/url]
Old 03-27-2018, 11:50 PM
look for at least one new video in the next 5-7 days. Thanks for following.
Old 04-02-2018, 10:02 PM
Just posted the lastest video a couple hours ago; https://youtu.be/nC7stYh4Bds
Old 04-02-2018, 10:23 PM
Some of the latest build pics:
finally got all the hydraulic cylinders mounted. good articulation on the bucket.
Old 04-02-2018, 10:29 PM
Bucket raised:
Big mouth: url=https://postimg.org/image/6yan8yt2f/][/url]
Old 04-02-2018, 10:32 PM
Almost 24" in length: url=https://postimg.org/image/r5o31bg9z/][/url]
Old 04-02-2018, 10:35 PM
Couple shots of the bucket tilt cylinder:
Although this model only has one bucket-tilt cylinder it is the biggest cylinder on the loader by far.
Tags
kit, lesu, liebherr, loader, wheel loader
