Euro Style Trucks and Trailers A place for the Euro style trucks single and twin axle trucks and trailers... |
Hi...
3 Years ago I started to plan the build of a Mercedes SLT Truck Here's a sample picture: ![]() The build started in October 2015, I bought a Actros 1851 Kit and some additional parts like axles and frames. ![]() The plan was to create the most parts on my own.
Greetinx Peter To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
My first milestone was to correct the measures of the stairs. I don't know why, but the stairs are different.
![]() ![]() ![]() The final version: ![]()
Next milestone: The Side plates of the technical tower
Let's start with the left side... ![]() ![]() Copy the line of the cabin ![]() Cutting the styreen plate following the line ![]() Follow up the lines of the cabin ![]() Cutting the outer lines ![]() Adding an angle at the top to follow the cabin ![]() Lower the middle part ![]() ![]() ![]() ![]() Adding a double layer at the top to get the rounding ![]() ![]() Last step, a border ![]() ![]() ![]() ![]()
The right side in pictures:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Both ![]() ![]() ![]() 75 EUR saved... ![]()
Next step, the frame
![]() ![]() ![]() Fenders added ![]()
The exhaust
![]() ![]() ![]() ![]() ![]() ![]() Two holdings ![]() Final ![]() ![]() ![]() Some more EUR saved... ![]()
A storage box hiding the charger contacts and the On/Off switch
![]() ![]() ![]() Two holdings added ![]()
The adblue Tank
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The holdings ![]() ![]() ![]() ![]() Finished... ![]() ![]() ![]()
The rear end, it was made with CNC by a forum colleague
The rear light holdings slightly modified
Next step, the working area with a small ladder
The next huge milestone: The tower
To join the parts of the tower I decided to create "shoes" for the connection points. They have more stability. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Placed on the frame ![]() ![]() ![]() The holdings for the side plates ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() ![]() ![]() Some air pressure tanks ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
The diesel and hydraulic oil tanks
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Two additional storage boxes (one will be modifed later) and one removed again. ![]() ![]() ![]() The boxes were planned to have the electronic parts, but that decission was changed later.
A small step, some working lights
After some test with the steering and some searches in the internet I decided to lift up the first fender by 5mm so that the tire no longer touches the fender if weight lies on the frame.
Some small items for the beacon lights
The oil cooler
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The air pressure tanks are slightly modified ![]() ![]() ![]() ![]()
Front and rear lights from Servonaut:
Next step with a lot of work, I wanted to change the mirror holdings. The solution of Tamiya is a real joke.
So I started to model some brass. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Currently Active Users Viewing This Thread: 47 (0 members and 47 guests) | |
Thread Tools | |
Display Modes | |
