Old 03-30-2018, 05:45 PM
Question Bearings in 3-speed gear box
In the instructions for the Grand Hauler there is a note telling NOT to replace two bushings with bearings. Is this a definite no, no, or is it okay to replace with bearings? Here is a picture.
Thanks, Big John.
Old 03-30-2018, 06:28 PM
mavrick0 mavrick0 is offline
mavrick0 is on a distinguished road
Default Re: Bearings in 3-speed gear box
I've replaced them before without any issues. I've never had to glue them either.
Old 03-30-2018, 09:43 PM
I have put bearings in other trucks, and I thought it was something that might have changed. Thanks for your input.
Old 03-31-2018, 08:59 AM
Yeah I didn't understand the change either. But then again looking at my king manual it doesn't tell you to glue them in either. So my only thought is they are worried about people getting glue on a ball bearing causing it not to roll which would jam everything.
Old 03-31-2018, 01:51 PM
I am real careful with super glue. But if the bearings fit snug, I won't worry about gluing them in place.
Old 03-31-2018, 01:58 PM
Wombii's Avatar
Wombii Wombii is offline
If I remember the gear box internals correctly, the reason it's advised not to replace with ball bearings is that those bearings need to both slide and roll freely. Ball bearings are usually not very good at sliding. Glue prevents them from popping out of the plastic thing from the push/pull force.
I have a feeling I greased that instead of gluing in my current build. Thanks for the reminder to check.
Old 03-31-2018, 02:09 PM
Thanks Wombii! Happy to help you remember to check.
Old 07-23-2021, 10:15 PM
Fury Fan Fury Fan is offline
Fury Fan is on a distinguished road
I am building my first KH and just finished the trans. Installed bearings throughout just prior to reading this thread. I have 1 bearing not sliding well, and I agree with Wombii. I'm going to swap those 2 bearings for the Tamiya bronze bushings.
Old 07-25-2021, 12:46 AM
Ball bearings are an unnecessary upgrade & a waste of money, the oillite bushing - bearings are way better & last much longer, especially in the drive axles, ball bearings wear out, oillites won't.
