Old 04-02-2018, 10:41 PM
Table Top Trucker Table Top Trucker is offline
Table Top Trucker is on a distinguished road
Default Re: Lesu Liebherr 574 loader kit build
Another shot of the valve assembly:
the hydraulic lines need to be trimmed and connected, I also need to run the lines between the valve assembly and the hydraulic pump.
If anybody has any tips for bleeding the air out of the system please speak up.
anybody know where i can find some kind of one-way tank vent. I don't want my hydraulic fluid spilling out if Im @ a weird angle.
Old 04-02-2018, 10:42 PM
Bucket tilt mechanism:
Old 04-03-2018, 02:53 AM
Rimrock Rimrock is offline
Regarding the tank-vent one usually just go for a bit longer hose, with the end placed at a higher point under the hood
Soyland Industrier
Old 04-03-2018, 12:30 PM
scottyk scottyk is offline
As temperature in the system goes up and down you will want the tank to vent both directions so I don't think you would want a check valve in there. I know some full size vents will be ran into a seperate vented/filtered overflow tank
Old 04-03-2018, 12:50 PM
Stuart's Avatar
Stuart Stuart is offline
Great job on the build and thanks for the pics.
Fumotec sells this vent filter: Vent
As for bleeding the system, I just fill it with oil and cycle the cylinders with the pump running at slow speed, keep topping up the oil as needed and cycle cylinders until all the air is out.
Old 05-18-2018, 08:31 AM
so, i guess postimage is dead?? anybody have a suggestion for a replacement??
Old 05-18-2018, 09:02 AM
here is a link to the latest video: https://youtu.be/YqmuZATpBn4
Old 05-20-2018, 05:38 AM
Post image changed the rules a while ago.
https://postimg.org/image/.... needs to become
https://postimg.cc/image/....
Let's try this.
Originally Posted by Table Top Trucker View Post
Couple shots of the bucket tilt cylinder:
https://postimg.org/image/nks7i4tqv/
No worky now.
https://postimg.cc/image/nks7i4tqv/
[/url]
Although this model only has one bucket-tilt cylinder it is the biggest cylinder on the loader by far.
Tags
kit, lesu, liebherr, loader, wheel loader
