#2341
#2342
It's not just a transfer case.....it's pure Awesomeness ! Getting closer and closer to move around on its own power.
#2343
Hi Cooper
Looking good man looking very good. It will soon be pushing you and the dog around under its own power. ![]() ![]() ![]()
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2344
should have a esc and motor arriving soon. Have the basics of the driveline done. Still need to weld up and some more details. This is a pic of the spider being machined. Did it in the mill then remove from collet block and part off on the lathe. Rotary table would be nice but don’t have one and then setting up for a simple opp,, I’ll keep with the collet blocks for now.
![]() And some shots of universal. ![]() ![]() ![]() ![]()
#2345
Get a Hardinge HV-4 5C collet indexer. Look on ebay.
You really don't need a rotary table since you have your CNC mill. |
#2346
Very nice, I like the idea of combining set screws with pins to connect the parts. Using thread lock to keep them from backing out? Also, how did you make the slip joint? Broach?
#2347
Yes the two joints , one under front frame and one right before rear pinion are broached keyway joints. With this driveline the universal is centered at articulation joint and the driveline is all on the same plane. So I don't need the driveshaft to slip in or out during use. But if for some reason the joints can be easily modified by only clamping on one end and letting the other float. The keyways are cut to length so keys cannot slip out if need be. I don't see needing any expansion/contraction joint on a one plane driveline, but it will not be know until I get a few more steps done. Hopefully tomorrow after all holiday events are done I'll have it spinning. I still need to cut gears from gearstock. Top and bottom transfer gears are boared and keyed, the two center gears I'm going to cut the shafts all in one with the gearstock. I'm waiting on a better fitting collet to arrive so I can machine the gearstock. I can center it in a 4jaw chuck with some soft shims so not to damage the gear but indicating it would be a pain in but. That's why I am waiting on a better sized collet, then I can use the collet blocks or even just the collet to hold it while lathe work.
#2348
Thanks for explanation. I agree that your particular setup doesn't need to slip back and forth during actual use and your two spline setup will work fine. Just noticed it in one of your pictures and was curious as to how you made it. I look forward to seeing the rest of this amazing build. Thanks very much for sharing.
#2349
Cooper, Get a soft collet and bore it to fit your gear diameter. |
#2350
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Transfer case done along with drive shafts. Also made a attachment plate for mounting motor to gearbox. Waiting on some gearstock to make a one piece coupler from motor to gear inside gearbox. Went with a fairly low kv motor that is sensored for easy start up and soft transfer of power to drivetrain. Using tekin rx8 esc with a 1400kv motor on 3s voltage. That gets a reduction in the gearbox of 4:1, 4:1, 3:1 then into transfer case all 1:1 then into axles with a 3:1 differential. Very similar to the haul truck. I think I used a 1900kv motor on that set up. With this machine I’m more looking for the motor to spin up closer to full speed while keeping machine slow and smooth power.
#2351
And that last pic, the motor and gearbox are underneath that plate. The 4 black bolts are some of the gearbox mounting hardware. Bunches of room on top and to the back for hydraulics and batteries
#2352
![]() ![]() ![]() Made split couplers for the driveshafts. Makes it easier to set the transfer case and line up. I still need to cut the keyway in them.
#2353
#2354
#2355
RW, at this pace, you'll have er up & runnin before next weekend!
#2356
![]() ![]() ![]() Received more gearblank today. Cut a one piece pinion and coupler to go from motor shaft to first stage of gearbox. Now I think I can think about getting her to move ![]()
#2357
#2358
Oh and another thing I did was to center drill a hole in the pivot joint pins. This will allow to properly align the universal joint with center of articulation. For it to function proper alignment is pretty critical. Straight no problem,
![]() ![]() This is a 3/16” drill poked through centerline hole to line up with spider pins in universal before tightening the other set screws and couplers. ![]()
#2359
Ahh pinion wire is so nice to turn on the lathe isn't it.
#2360
I really look forward to watching what you come up with for a screening plant. I would bet it's going to be awsome.
Currently Active Users Viewing This Thread: 17 (0 members and 17 guests) | |
