Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
#522
So the electronic control box on the lathe exploded.........So winch drum has to wait a bit. Onward with the next step.
[IMG] ![]() Mast section fixpoint. and a cab testing mockup also. looks little small, Or? [IMG] ![]() The steering assembly is there, still, need a bit tweaking. [IMG] ![]() |
#524
Looks good!
Kerst |
#525
A huge terminal forklift looks like so much fun to play with! Especially one as nice as this. I think the cab is about the right size compared to the wheel size, but on those I've seen the cab is mounted a bit further back, behind the front wheels instead of over them. That difference might give the illusion of a longer wheelbase and smaller cab, maybe?
#526
You're spot on Wombii. I'll do a few more fitting today, to see where it goes. Thanks for your input, much appreciated.
#527
Pretty cool stuff you got going on sir bo!!! Before long I shall see it in person!!
#528
I had to make a static load test, 6 kilos 2 inch in front of drive axle center. that gives zero kilos on the steer axle, with no counterweight on the rear part.
[IMG] ![]() And placed the cab further back looks like a splendid idea Wombii. Sometimes you get lost in your own thinking......... ![]() ![]() [IMG] ![]() By the way, I wanna lift 12.66 Kilos when all is done........should be 35 metric ton. ![]() Oh! well carry on with next step....... |
#529
#534
Looks great! I would be happy with that.
#535
That's a heck of an upgrade!
The cab might be a little small, hard to tell without a truck or a figure around. It might like the bottom of the door lowered a bit more I can't wait to see what this turns into!
#536
[IMG] ![]() Thanks for your input Frizzen. Yes, the cab is little small, not sure if I'm changing or not. Went to Tractor Supply today, And this Mack fell in my arms.......Had to save it from some kid...... ![]() [IMG] ![]() |
#538
I like the ford tractor cab, it reminds me of a control tower, some aircraft tugs, and a few fire engines from the 70s. But I was trying to scale it off a big Hyster at work, i've never been around the container handlers. I definately wasn't criticizing, it looks cool.
Nice score on the crane, i didn't know TSC had those back in yet
#539
The size of the cab is bugging me a bit. but this one needs that Ford Cab i think. Next one is a different story. The Crane has broken down already ![]() |
#540
The steering is now done. Works perfectly.
[IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() And now a dive into Battery holders and a few other under the shell kind of thing. |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
Thread Tools | |
Display Modes | |
