Old 11-15-2018, 12:43 PM
Bo Wallen's Avatar
Exclamation Re: KH Beam Hauler
Got my electronic box for the lathe back today. So now I can make winch drum and other round things I need.
[IMG]IMG_3503 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3505 by Bo Wallen, on Flickr[/IMG]
The day after humpday is always good.
Old 11-15-2018, 09:35 PM
Bo Wallen's Avatar
Lightbulb Re: KH Beam Hauler
Mor of the same pill.
[IMG]IMG_3506 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3507 by Bo Wallen, on Flickr[/IMG]
Old 11-16-2018, 05:24 PM
Bo Wallen's Avatar
Battery Holder Time After that, it's Friday Cocktail hours.
[IMG]IMG_3509 by Bo Wallen, on Flickr[/IMG]
Old 11-17-2018, 03:16 PM
Trucking4u's Avatar
Trucking4u Trucking4u is offline
Trucking4u is on a distinguished road
Default Re: KH Beam Hauler
Lookin Good Bo!
Jon in Vt.
The northern Rednecker
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you!
Old 11-17-2018, 03:17 PM
Bo Wallen's Avatar
One Powerpack installed two more to go.
[IMG]IMG_3511 by Bo Wallen, on Flickr[/IMG]
Old 11-19-2018, 08:16 PM
Bo Wallen's Avatar
A bit of this and that.
[IMG]IMG_3518 by Bo Wallen, on Flickr[/IMG]
[IMG]IMG_3519 by Bo Wallen, on Flickr[/IMG]
Old 11-19-2018, 09:46 PM
Bo Wallen's Avatar
Thumbs up Re: KH Beam Hauler
Second Battery mounted.
[IMG]IMG_3520 by Bo Wallen, on Flickr[/IMG]
Old 11-20-2018, 01:09 PM
Wombii's Avatar
Wombii Wombii is offline
You're using 3 battery packs?
Old 11-20-2018, 04:37 PM
Bo Wallen's Avatar
Yes, I do in this one. And two in all my trucks. Last all day that way I can charge overnight and be ready for battle bright and early morning on shows.
Old 11-20-2018, 06:18 PM
Bo Wallen's Avatar
And the battery holders are all installed. Now to the upper structure and lift mast. Exiting.
[IMG]IMG_3521 by Bo Wallen, on Flickr[/IMG]
Old 11-20-2018, 07:15 PM
What kind of gearbox are you using on your winch?
Old 11-20-2018, 07:30 PM
Bo Wallen's Avatar
Not sure which one yet. Testing a few to find out a winner. First up is this one.https://www.robotshop.com/en/6vdc-40...ear-motor.html
The second will be this one. https://www.robotshop.com/en/6vdc-16...ear-motor.html
And if that does fail I go to the bigger guns. Worm Gear is a must-have for holding the load.
https://www.amazon.com/Torque-Turbo-...997683015&th=1
Old 11-20-2018, 07:36 PM
Bo Wallen's Avatar
The current weight as it sits on the previous picture is 3.23 KG or 7.2 Lb
Old 11-21-2018, 08:48 AM
Wombii's Avatar
Do you run them in parallel or do you use one for drive and one for accessories?
I like how low you got them mounted. Looks like it would be a fun and solid racing truck at this stage.
Old 11-21-2018, 10:05 AM
Bo Wallen's Avatar
Do you run them in parallel or do you use one for the drive and one for accessories?
In this Forky I run 2x 7.2 Volt for driving and lifting stuff. the third is for lights and funky functions. If it was a race truck I'd lay the battery flat. Hmmmm. Race Truck! That could be a cool thing, I might look into that.
Old 11-24-2018, 01:04 PM
That thang is looking good. Looks like it'll be a real workhorse.
Old 11-26-2018, 11:04 PM
Bo Wallen's Avatar
Thanks, Skeeter. Yes, this is going to be on heavy-duty jobs, around the yard. Been busy with the holiday and that thing they call work. Anyway, the lift test is on the way, so far so good, might have to get a stronger lift motor. I suppose I have a high demand for this unit.
[IMG]IMG_3572 by Bo Wallen, on Flickr[/IMG]
Old 11-26-2018, 11:58 PM
Before you go ordering other motors, might want to take a couple passes off the cable bed of your winch drum. Smaller diameter gives slower line speed, but less moment the torque from the line has against the motor.
Old 11-27-2018, 12:36 AM
Bo Wallen's Avatar
Good eye Frizzen. I have one more winch drum sitting in the lathe right now, just need a better axle to fit the bearings. One more bottleneck is the wire gauge also. Need to get bigger and shorter wire, they get an itty bitty hot
The lift mast is one other story, lots of friction and bending. Cheapest plastic I've seen in a long time. I might have to bite the bullet and make a better one, now when the rest of "Forky" run so good.
Old 11-27-2018, 02:05 PM
Bo Wallen's Avatar
One aerial shot before the missing body parts and counterweights go on.
[IMG]IMG_3562 by Bo Wallen, on Flickr[/IMG]
Currently Active Users Viewing This Thread: 29 (0 members and 29 guests)
