#81
#82
Hemi
Superb workmanship and really inspirational project. I have question on your homemade cylinders. Do you use a specific steel for the rod, ie precision ground drill rod, or regular steel? Also what type of oring? Silicone? Viton? I really want to try to make a working cylinder for a dozer. Love the grader - masterpiece! Best regards, Bob |
#83
This build is AMAZING! This will be super cool when everything is done & this masterpiece is moving dirt.
#84
For the rods I use 1.4021 stainless steel. I'm using both Nitrile and Viton o-rings.
#85
#86
#87
Nice work as usual Ari!
#88
Great job you are doing here Hemi ! May i ask what type/grade of aluminium you machine ? I want to use 6061-t6 for my project but maybe you have a better alternative ?
#89
I'm mostly using 6061, but I also have some harder aluminium that I have no idea what it is.
#90
I've been working with the circle gear, and I got it almost machined when it came loose off the chuck. I could not tighten the chuck very tight because the circle gear is not very thick. I was taking very moderate cuts and relatively slow speed, but it was not enough
![]() I have to try again, and do the final operation with different mounting method. Luckily some parts turn out decently. ![]() ![]()
#91
That's a sad let down! The part looked like it would have been beautiful, before the catastrophe.
#92
Bummer
![]() ![]() On your piece; Could you cast it in some of that Bismuth alloy? If you don't know what that is, it's a soft lead type metal that melts in hot water. |
#93
Ari To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Hemi1966; 03-02-2019 at 07:26 AM. |
#94
Excellent job Ari you are a real artist with your Graders. Ed
#95
Glad it worked out for you second time around! Looks beautiful!
#96
Thanks guys
![]() I got the centershift cylinder and few brackets done. On the last pictures you can see some extreme angles of the drawbar. ![]() ![]() ![]() ![]() ![]()
#97
#98
That is insane .....
#99
#100
Nice work Ari ..3D cad can be very challenging at the best of times .your first grader build inspired me to build one as well..Your work blows me away .mine has been coming along fairly well and always trying to do some upgrades and details ..heres a vid of it doing some snow work ..
https://www.youtube.com/watch?v=JZTlPB4x5fs |
